Finding Components of Cross Product for Vectors A and B
The discussion revolves around finding the components of the cross product of two vectors, A and B, given in two-dimensional form. The original poster presents their vectors as A = 3.5i + 1.8j and B = 1.7i + 4.8j, and expresses confusion regarding the calculation of the k component of the cross product.
  • The original poster attempts to calculate the cross product using the magnitude formula and expresses frustration over receiving incorrect component values. They question where their reasoning may be flawed and explore the use of individual components in their calculations.
Participants are providing guidance on the correct approach to calculating the cross product, emphasizing the need to consider the vector as a determinant rather than just calculating magnitude. Some participants clarify the nature of the resultant vector and its orthogonality to the original vectors.
There is an indication that the original poster is working within the constraints of a homework platform that requires specific component answers, which may not align with their current understanding of the cross product calculation.
angel120
Vector A = 3.5i + 1.8j and vector B = 1.7i + 4.8j . Find the components of A x B:
AxB = AB sin(theta)
Since vector A=3.5i+1.8j and B=1.7i+4.8j, I translated that into vectors. So, A is 3.94 @ 27.77*, and B is 5.09 @ 70.56*. This means that the angle between A and B is 42.79*.
Using the AxB formula, I have 13.62. However, the problem (it's on WebAssign) wants the i, j, and k components.
I tried the AxB formula with the individual i and j components, and I got 4.04 for the i direction, and 5.87 for the j direction. However, they're both wrong, and I have no idea how to find out the k direction...
Help!
Thanks in advance,
-Angel.
k is the third dimesion (or 3rd component in this case). A and B are 2 dimensions.
I understand that the i, j, and k components are the x, y, and z directions, respectively. My frustration is that I believe I'm following the correct formula, but I still get the wrong answer. Where is my reasoning flawed?
I have tried the following:
AxB = (3.94)(5.09)sin(42.79) = 13.62, however, WebAssign wants the answer in components.
So, I tried this:
AxB = (3.5i)(1.7i)sin(42.79) = 4.04i
and then
AxB = (1.8)(4.8)sin(42.79) = 5.87j
When I entered these two (out of three) answers, they were both marked wrong.
The formula you try to use is for the magnitude of the vector axb, but the question asks for the vector itself.
Do you know the way to calculate a cross product as if it were a determinant?
axb=|i j k; a_i a_j a_k; b_i b_j b_k|
When you cross two vectors the resultant vector will be orthogonal to both original vectors. Keep that in mind.
You can multiply by components, but:
i x i=0 (same for j x j)
i x j =k
j x i = -k
Try this.
Newer mind the sin. Multiply the two vectors as you'll do for two binomials.
