Understanding Limits: Common Mistakes and How to Find Bounds
  • Thread starter Thread starter Дьявол
    Concrete Limits
The discussion revolves around understanding limits in calculus, specifically focusing on common misconceptions and the behavior of functions as they approach certain values. Participants explore limits involving trigonometric functions, exponential functions, and rational expressions.
  • Participants discuss the limit of sin(x)/x as x approaches 0, questioning the accuracy of their calculator settings. They also explore the limit of 1/x as x approaches infinity, raising concerns about the behavior of the function for specific fractions. Additionally, they examine the limit of e^(1/x) as x approaches 0 from the negative side, seeking to understand how to demonstrate the result of this limit.
Some participants have clarified their misunderstandings regarding calculator settings and the behavior of limits. There is ongoing exploration of how to rigorously show the results of certain limits, particularly for exponential functions. Multiple interpretations of the limits are being discussed, indicating a productive exchange of ideas.
Participants are working within the constraints of homework assignments, which may limit the depth of their explorations. There is an emphasis on understanding rather than simply obtaining answers, with some participants expressing a need for further explanation or proof of concepts discussed.
Дьявол
Hello! I got few questions, about limits.
º [tex]\lim_{x \rightarrow 0}(\frac{sin(x)}{x})=1[/tex]
If I take values for x close to zero I get:
f(x)=sinx/x
f(0.1)=0.017453283
f(0.01)=0.017453292
as I can see it is not even close to 1.
What is the problem? Where I am doing wrong?
º [tex]\lim_{x \rightarrow \infty}(\frac{1}{x})=0[/tex]
Now, for all integers I agree that [tex]\lim_{x \rightarrow \infty}(\frac{1}{x})=0[/tex] (thanks to HallsofIvy for [itex]\infty[/itex]), but what for 1/2, 1/3, 1/4 ?
[tex]\lim_{x \rightarrow \infty}(\frac{1}{x})=\frac{1}{1/4}=4[/tex] and not 0 ?
º [tex]\lim_{x \rightarrow 0^-}(e^{\frac{1}{x}})[/tex]
How will I find the bound of the expression above?
I understand that x<0 (so the values for x are tending to 0 from the left side), and
[tex]\lim_{n \rightarrow \infty}(x_n)=0[/tex]
For example, I know how to find the bound for:
[tex]\lim_{x \rightarrow 2^+}(\frac{x}{x-2})[/tex]
D=R\{2}
xn>2
[tex]\lim_{n \rightarrow \infty}(x_n)=2[/tex]
[tex]x_n-2>0[/tex]
[tex]\lim_{n \rightarrow \infty}(x_n-2)=0[/tex]
so that:
[tex]\lim_{x \rightarrow 2^+}(\frac{x}{x-2})=\lim_{n \rightarrow \infty}(\frac{x_n}{x_n-2})=\frac{2}{\lim_{n \rightarrow \infty}(2-x_n)}=+\infty[/tex]
Thanks in advance.
f(x)=sinx/x
f(0.1)=0.017453283
f(0.01)=0.017453292
Are you using a calculator to do these? If so, I think your calculator is in degree mode. It needs to be in radian mode. As the values of x get smaller, the value of your expression will get closer to 1.
The limit is for x growing very large, so you shouldn't concern yourself with small values of x. On the other hand,
[tex]\lim_{x \rightarrow 0^+}(\frac{1}{x})=\infty[/tex]
which is more related to what you're doing with 1/2, 1/3, and so on.
As x approaches 0 from the negative side, 1/x approaches neg. infinity, so e^(1/x) approaches 0. Do you need more explanation than that?
D=R\{2}
xn>2
[tex]x_n-2>0[/tex]
so that:
Thanks in advance.
Thanks for the post Mark44.
Yes, I was using calculator in degree mode. Now with radian mode everything is all right.
For the second one. Sorry, I wasn't so clear. I was learning about the number "e". So for one task (example):
[tex]\lim_{x \rightarrow \infty}(1+\frac{1}{x-3})=\lim_{x \rightarrow \infty}(1+\frac{1}{x-3})^{(x-3)+3}=\lim_{t \rightarrow \infty}(1+\frac{1}{t})^t*\lim_{t \rightarrow \infty}(1+\frac{1}{t})^3=e*(1+0)^3=e[/tex]
As we can see they put [tex]\lim_{t \rightarrow \infty}(\frac{1}{t})=0[/tex]. How is this possible? What about for t=1/2,1/3,1/4 ? It wouldn't be zero in that case.
Mark44, sorry for misunderstanding again. Yes I understand all of that, but how will I "show" or "prove" that. Aren't there any calculations?
Thanks in advance.
For your first limit above, I think you are missing an exponent of x. In other words, I think it should be:
[tex]\lim_{x \rightarrow \infty}(1+\frac{1}{x-3})^x[/tex]
Now I think I understand what you're saying. The first limit was as x approached infinity and involved an expression with (x - 3). They substituted t = x - 3 and changed the limit variable from x to t (as x gets very large, so does t).
In the third limit expression (before they took the limit), there are two factors:
[tex]}(1+\frac{1}{t})^t[/tex] and
[tex]}(1+\frac{1}{t})^3[/tex].
The second one is straightforward to evaluate in the limit, and turns out to be just 1. If you multiply it out before taking the limit, you have 1 + 3*1/t + 3*1/t^2 + 1/t^3, which approaches 1 as t gets large.
The first one is more tricky, and you can't just say that 1/t approaches 0 as t gets large. There are two competing effects going on: the base, 1 + 1/t, is getting closer to 1, but the exponent t is getting larger. The net effect is that (1 + 1/t)^t approaches the number e as t gets large. If I recall correctly, one of the definitions of e is precisely this limit.
Thanks in advance.
Now I understand. I misjudged [itex]\infty[/itex].
But for [tex]\lim_{x \rightarrow 0^-}(e^{1/x})[/tex], I need to "show", "explain" the result of the limit. How will I do that?
Regards.
For x very close to 0, but negative, say -0.00001, 1/x is -100000, a very large negative number. What is e-100000? what is e any very large negative number?
Thanks for the post. It definitely will tend to zero.
And what about [tex]\lim_{x \rightarrow 0^+}(\frac{1}{1+e^{1/x}})[/tex]?
[tex]\lim_{x \rightarrow 0^+}(e^{1/x})=\infty[/tex] ?
For the first one, as x approaches 0 (from the right), 1/x grows without bound (approaches infinity), so 1 + 1/x also grows without bound, which makes the fraction approach 0.
For the second, that's the right value.
  • · Replies 17 ·
  • · Replies 25 ·
  • · Replies 18 ·
