View Single Post
Apr26-09, 04:33 PM   #1
Determining Uncertainty in Position using Heinsburg's Uncertainty Principle
1. The problem statement, all variables and given/known data
A 52.9 g ball moves at 12.2 m/s.
If its speed is measured to an accuracy of
0.04%, what is the minimum uncertainty in
its position? Answer in units of m.
2. Relevant equations
delta x times delta p = 1/2 (h/2pi)
3. The attempt at a solution
I used the uncertainty of the speed to determine the minimum and maximum momentums for the ball. I used these to determine what delta p is equal to (0.6195648) and then substituted that number into the equation to solve for delta x. I used kilograms for the mass, which I believe are the correct units as opposed to just grams. If you could help me determine what I am doing wrong, that would be great! Thanks!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
