Understanding Fusion Power: Deuterium & Tritium in Magnetic Confinement
The discussion revolves around the operation of fusion power, specifically focusing on the roles of deuterium and tritium in magnetic confinement systems like tokamaks. Participants explore the methods of introducing these fuels into the plasma and the implications for fusion reactions.
  • One participant seeks guidance on how deuterium and tritium are introduced into a tokamak and their operational roles during thermonuclear reactions.
  • Another participant explains that deuterium and tritium are ionized to form plasma, which is confined by magnetic fields, and discusses the dynamics of ions and electrons within the plasma.
  • A different viewpoint suggests that additional fuel can be introduced via frozen pellets of deuterium and tritium, noting that the plasma density is lower than expected.
  • One participant mentions that the amount of fuel required depends on the expected output power of the fusion reactor, indicating variability based on reactor size.
  • A question arises regarding whether the fuel is initially introduced as gas or frozen pellets, leading to some confusion about the process.
Participants express differing views on the method of introducing fuel into the tokamak and the implications for fuel quantity based on reactor design. The discussion remains unresolved regarding the specifics of fuel introduction and the exact amounts needed for different reactor scales.
Participants mention various assumptions about the state of the fuel (gas vs. frozen pellets) and the dependence on reactor design, but these aspects remain unclear and are not fully resolved.
This discussion may be useful for individuals interested in fusion power technology, particularly those exploring the specifics of fuel management in magnetic confinement systems.
ozgurakkas
I have been researching about fusion power to understand how it operates during thermonuclear reactions. I do not understand how and how much deuterium and tritium are placed into the magnetic confinement (tokomak). I appreciate it, if anyone guides me about this.
Thank you
Thank you
The deuterium and tritium are ionized to form a plasma, and the plasma (ions and electrons) are confined by the magnetic field. The plasma excludes the magnetic field, and the ions and electrons rotate or more accurately, spiral along the magnetic field lines. The stronger the magnetic field (greater line density), the small the gyroradius of the ions and electrons. Within the plasma, where the magnetic field is low or virtually non-existent, the ions and electrons would have very large gyroradii, but they also scatter off each other.
Basically in a torus, one starts with a neutral gas which is heated rapidly with a toroidal current (ohmic heating). That current is also subjected to an azimuthal magnetic field (caused by the toroidal current) which pushes inward on the current and then plasma, which forms as the neutral gas is heated by the current. Toroidal and poloidal magnetic fields are also applied for additional confinement and stability.
Additional fuel is proposed to be added in a reactor set up with fuel pellet injection. Frozen deuterium and tritium in small pellets are shot into the plasma through the magnetic field. Compared to what you experience daily, a plasma is not that dense, so there's actually much less fuel than what I expected. Exactly how much depends on the volume of confinement.
Hi there,
In the idea of fusion power, the amount of combustible needed will depend mainly on your expected output power. If you want to have a small experimental fusion plant compared to a few 1000MWe, will vary the amount of fuel needed.
Cheers
Now, I am a little confused. Is it sent into the tokomak in the form or gas or injected as frozen pellets. Maybe, It starts with neutral gas and later fed with D-T ice pellets?
Thanks. Your answers made it clear. I also got some anwsers in this website..
http://www.fusion.org.uk/info/glossary/glossmain.htm
