Full DC Recovery for Variable Amplitude Sine Signal
  • Thread starter Thread starter 0xDEADBEEF
    Dc
This discussion focuses on achieving full DC recovery for a variable amplitude sine signal, specifically one that ranges from +2U to 0. A common method mentioned involves using a diode and capacitor in series, but this approach results in a diode drop that prevents reaching 0 volts. Participants suggest using operational amplifiers (op-amps) to eliminate the diode drop by implementing both positive and negative peak detectors, followed by a stage to compute the mean value. Additionally, quadrature methods are discussed, although they would double the frequency of the signal.
  • Understanding of DC recovery techniques
  • Familiarity with operational amplifiers (op-amps)
  • Knowledge of peak detection circuits
  • Basic concepts of signal processing
  • Research operational amplifier configurations for peak detection
  • Explore standard circuits for DC recovery in variable amplitude signals
  • Investigate low distortion quadrature signal processing techniques
  • Study the impact of diode drops in rectification circuits
Electronics engineers, signal processing specialists, and anyone involved in designing circuits for DC recovery of variable amplitude signals.
0xDEADBEEF
I need to do dc recovery on a sine signal with a variable amplitude. (so its not between +U and -U but between +2U and 0) It is fast enough if the offsets adjusts within minutes. There is a quick hack in the Art of electronics, where they set a diode and a capacitor in series, but this leaves me one diode drop below 0. Is there a nice (possibly standard) circuit that does a full dc recovery. I try to keep the distortion low.
Another way would be quadrature although this would double the frequency. Can anyone recommend a good low distortion chip there.
You can use an opamp to get rid of the diode drop in rectification and peak detection. You can do a + peak detector and a - peak detector, and then a single stage after that to give you the mean value.
http://en.wikipedia.org/wiki/Peak_detector#Peak_detector
  • · Replies 24 ·
  • · Replies 46 ·
