Increase Amps with 12V to 24V Conversion - Any Help?
  • Thread starter Thread starter agabrielauto
    12v Converter
The discussion focuses on the relationship between voltage and current, specifically addressing how to increase current (amps) when converting from 12V to 24V. It is established that according to Ohm's Law (I = V/R), increasing voltage will decrease current if resistance remains constant. To increase current, one can either increase the voltage or decrease the resistance. The conversation also touches on the role of transformers in voltage and current transformation, clarifying that the current in the primary circuit is influenced by the secondary circuit's load.
  • Understanding of Ohm's Law (I = V/R)
  • Basic knowledge of electrical resistance
  • Familiarity with transformer operation
  • Concept of voltage and current relationship in circuits
  • Research transformer design and functionality
  • Learn about different types of resistors and their impact on current
  • Explore power supply specifications for voltage and current adjustments
  • Study advanced circuit analysis techniques
Electrical engineers, hobbyists working with power electronics, and anyone involved in circuit design and analysis will benefit from this discussion.
agabrielauto
when u go up in volts then your amps will go down.
How can I then increase amps?.
Is it just by increasing the power of the source?
Any help. Explain please.
Very simple, the current is determined by the effective resistance of the element.
The current through an element is based on resistance/voltage, and then just use ohm's law (V/R=I)
The easiest case is resistance. The two ways to increase current through a resistor is to either up the voltage or to pick a resistor with less resistance.
EDIT:
I am slightly confused by your title though. If you mean a transformer that's a different topic altogether.
For example, original case, 2x change in windings. Thus you double up voltage. Now this means that current in the primary circuit will be twice more than in the secondary. The current is set by the secondary on the primary. The voltage is set by the primary.
Thanks for your answer. I will try to make a better explanation later today.
  • · Replies 33 ·
  • · Replies 19 ·
19K
