Is nondetection of SUSY @ Tev a problem low energy SUSY?
  • Context: Graduate
  • Thread starter Thread starter ensabah6
    Energy Susy
The Tevatron has not detected multiple Higgs bosons or any SUSY particles, raising concerns about the viability of low-energy SUSY as an explanation for Higgs stabilization. Current data and energy levels suggest that the likelihood of finding SUSY at the LHC may be diminished due to the non-observation of SUSY at the Tevatron, which has ruled out squarks and gluinos up to 300-400 GeV. However, the constraints on neutralinos remain weaker, indicating that more data is required to make definitive conclusions about the Standard Model Higgs. The future operation of the Tevatron is uncertain, with discussions about its potential shutdown in 2010 or possibly extending to 2013 depending on funding.
  • Understanding of Supersymmetry (SUSY) concepts
  • Familiarity with Higgs boson theories
  • Knowledge of particle physics experiments, specifically Tevatron and LHC
  • Awareness of particle decay processes, including proton decay
  • Research the implications of non-detection of SUSY at the LHC
  • Explore the current status and future plans for the Tevatron
  • Investigate the constraints on neutralinos and their significance in SUSY
  • Study the relationship between Higgs stabilization and SUSY theories
Particle physicists, researchers in theoretical physics, and anyone interested in the implications of SUSY and Higgs boson research.
The non-observation of SUSY/Higgs at Tevatron & SUSY
  • other (please specify)
    Votes: 0 0.0%
  • Total voters
ensabah6
Thus far Tevatron has not detected any multiple higgs bosons or any SUSY particles. If SUSY is the correct explanation for Higgs stabilization, given both the amount of data and energies reached, does this present a problem (i.e makes more unlikely) SUSY as an explanation for Higgs stabilization? Presumably it might be another couple of years before LHC has enough data to find either Higgs of SUSY during which Tevatron will continue to collect data.
Does the continued non-observation of SUSY at Tevatron, combined with no-observation of proton decay, make finding SUSY less likely to appear at LHC or it has no bearing on whether LHC will see SUSY?
"given both the amount of data and energies reached"
That amount is too small to make conclusions. Tevatron has ruled out squarks and gluinos up to 300-400 GeV. Constraints on neutralinos are substantially weaker. It would take several times the amount of data collected to rule out Standard Model Higgs.
I'm not sure how long we can expect Tevatron to continue operating. The Wikipedia article says that it will be shut down in 2010. I recall reading statements to the contrary. If there's enough money to keep it running as is through 2013, only then it will stand a chance to cut out a sizable chunk of SUSY parameter space.
  • · Replies 24 ·
