Windows or Ubuntu for an Electric Engineering student?
The discussion revolves around the choice of operating systems for an Electrical Engineering student, specifically comparing Windows XP and Ubuntu. Participants explore the implications of each OS for academic and project work, including considerations for dual booting and virtual machines.
  • One participant suggests that both Windows XP and Ubuntu can run the necessary programs, with Wine as a potential solution for compatibility.
  • Another participant advises checking departmental preferences, noting that their EE department primarily uses Windows XP, which is unsupported.
  • Some participants propose dual booting as a viable option to utilize both operating systems effectively.
  • There is a suggestion to use a virtual machine (VM) due to sufficient system resources, with a question about which OS would serve better as the host for VMs.
  • One participant argues that Ubuntu is preferable for robotics and hardware interfacing due to easier access to source code and simpler interfacing compared to Windows.
  • Concerns are raised about potential issues with mouse response times and hardware interfacing when using VMs, suggesting that the choice of host OS may depend on the user's specific needs.
Participants express differing opinions on the best operating system, with some advocating for Ubuntu due to its advantages in certain applications, while others highlight the prevalence of Windows XP in their academic environment. The discussion remains unresolved regarding which OS is definitively better for the student’s needs.
Participants mention the unsupported status of Windows XP and the varying experiences with hardware interfacing in both operating systems, indicating that the choice may depend on specific project requirements and personal preferences.
SuperMiguel
Im an Electric Engineers student and I am trying to decide to use Windows XP or Ubuntu.. Most of the programs i need will run in both if not wine will do...
What do you guys think?
System has a quadcore CPU, 2TB HD and 16gb of ram.. (I know kinda overkill but i got it for free)
Computer science news on Phys.org
Find out what your department uses and go from there?
You shouldn't use XP 'cause it's unsupported and ubuntu is a good way to learn other operating systems, but at least at my school the EE department mostly uses XP and I'm stuck encouraging ubuntu for robotics projects.
they use windows xp :(
Why not dual boot?
zpconn said:
Why not dual boot?
i guess i could do that
Or use a vm since you've got enough gigs for it. Use the OS you want to stick with as the host and throw the experimental os on the vm.
whats a better host for vms ubuntu or windows??
Ubuntu linux will be a smarter choose as for robotics and other hardware interfacing stuff … you will realize linux has tons of source code available …. and parallel or serial interface in linux systems is easier if you try ..that in windows … you have to go through elaborate NT kernel apis to do so .. or if you could use some libraries in VB.
But VB as such sucks for moderately complex setup … or where u want to use some functional programming language like Newton script or haskell and want to call some C libraries or vice versa. So use Linux it will save u lot of trouble and you can focus on the project instead of vast Interfaces to the operating system.
*shrugs* Depends on what you want to do. If you game a lot, you may want windows to be the host system 'cause I've heard of some issues with mouse response times in vms. I've also heard of some issues with hardware interfacing issues with vms, so you may just want to make the host system whichever one you expect to use more with hardware.
no gaming at all
+1 for dual booting.
bah ubuntu it is
  • · Replies 21 ·
11K
13K
  • · Replies 16 ·
93K
