Gain of an Amplifier: Av & Gv Explained
  • Thread starter Thread starter Danish_Khatri
    Gain Transistor
The discussion clarifies the distinction between voltage gain (Av) and overall gain (Gv) in amplifiers, particularly in a common emitter configuration. Av is defined as the ratio of output voltage to input voltage, while Gv refers to the ratio of output voltage to the open circuit voltage of the source generator. The overall gain considers the power transfer limitations, emphasizing that power cannot exceed unity despite high voltage gain. Understanding these concepts requires recognizing that a transistor's gain is context-dependent and operates within a circuit. The explanation ultimately helps clarify the differences between these two types of gain in amplifier design.
Danish_Khatri
I am studying the design of an amplifier in common emitter configuration. I am studying from microelectronic circuits by sedra and smith. the author has described two terms for gain of a amplifier. one is the represented by Av and is called the voltage gain of that amplifier and the other is Gv called the overall gain of amplifier. I m not able to understand the difference between the two. can anybody help me out with this confusion?
Voltage gain just says what it says. It is the ratio of the volts out over the volts in.
'Overall gain' will be referring to the gain in actual Power, that is achieved. After all, a transformer can give you a voltage gain of 100, but the power transferred can't be greater than unity.
It's a matter of input impedance and output impedance. For instance, if you want to feed 100V into 50Ω you need 200W. To feed 100V into 1kΩ you only need 10W.
Dear I was not able to grasp on your answer. would you please explain it in terms of transistor itself
Depending on the edition that you have, in the fifth edition Sedra/Smith on page 463 the quantities G_v and A_v are clearly defined.
G_v is the ratio of v_out to the open voltage of the source generator (it's not the input voltage of the amplifier).
A_v is the ratio of v_out to the input voltage of the amplifier.
A fair enough question but you need to realize that a transistor never operates in isolation. It is part of an amplifying circuit and it has no inherent Voltage Gain without being in a circuit - you actually state your question in the context of a common emitter circuit so you appreciate what I have just said.
Thanks for your help dear. I understood this concept when I repeated the paragraph.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
