Dale
Mentor
- 36,901
- 15,878
An array of dipoles is not a multiphase linear motor. A linear motor needs a primary and a secondary, not just one of the two. The energy moves from the primary to the secondary at the speed of light, not at the phase velocity.Cosmos2001 said:In a multiphasic linear motor, if (v<c), energy move at the phase velocity, it is hard to refute this; I think is a true fact for (v<c) because without this the linear motor would not work.
No. If v>c then you will just have an ineffective transfer of energy from the primary to the secondary. Most of the energy will just be radiated away or dissipated as heat.Cosmos2001 said:My hypothesis is, if (v>c), the energy will move forcedly at the phase velocity, facing relativistic resistance.
It is only a hypothesis.
Always seeing it as a multiphasic linear motor: if (v<c) then energy will flow along it in a non-forced way because it will not face relativistic resistance, energy will be dissipated into outgoing multiphasic waves increasing their amplitude. If (v>c) then energy will face relativistic resistance in order to be dissipated into the outgoing multiphasic waves, relativistic resistance will become a hypothetical relativistic support.
Just Google "phased array" and "phase velocity" to see what is there. I think you need to learn some basic EM concepts before worrying too much about the experimental details and relativistic effects. Specifically you should learn about motors and dipole antennas.Cosmos2001 said:DaleSpam, I have no problem with you proving I’m wrong, if you can I’m grateful to you, but I felt I’m failing in describing my point of view.
Well, I know that “lots of experiments have been done with phase velocities >c”, but I’m not finding out one using an array of dipoles.
Please, could you give some clue to finding it?
