I have a set of numbers, how do I go about proving they form a field
To prove that a set of numbers forms a field, one must demonstrate that it satisfies specific algebraic structures. A field requires two binary operations, addition and multiplication, which must be commutative and associative. Additionally, the set must contain an additive identity (0) and a multiplicative identity (1), with every element having an additive inverse and a multiplicative inverse, except for the additive identity. The discussion highlights the importance of verifying these properties through the use of operation tables.
  • Understanding of algebraic structures, specifically fields
  • Familiarity with binary operations and their properties
  • Knowledge of commutative and associative laws
  • Ability to construct and analyze operation tables for addition and multiplication
  • Study the properties of fields in abstract algebra
  • Learn how to construct operation tables for binary operations
  • Explore examples of fields, such as rational numbers and finite fields
  • Investigate the concept of additive and multiplicative inverses in detail
Students and educators in mathematics, particularly those studying abstract algebra, as well as anyone interested in understanding the foundational concepts of fields and their properties.
andrey21
Heres what I know
It has to be commutative under addition, which should give symmetry down the leading diagonal, which it does. What else must I show??
Thanks in advance
I don't quite understand what you are talking about. A "set of numbers"? That doesn't form a field- a single set is not a field. A field is a set of objects (which might or might not be numbers) together with two binary operations called "+" and "*". They must satisfy several laws:
1) They form a commutative group with addition (so, yes, commutative under addition but also associative, there exist an additive identity (0), and every member has an additive inverse.
2) Multiplication is commutative and associative and the distributive law holds. There is a multiplicative identity land every element except 0 (the additive identity) has a multiplicative inverse.
I have no idea what you mean by "symmetry down the leading diagonal". Are you referring to a diagonal in the additive or multiplcative tables? If so, that is just saying "commutative" again.
Yes sorry I didn't word the question very well. I do have two tables for "+" and "*". In the + table is does have symmetry down the leading diagonal, so that is commutative. There does exist a zero, what do you mean by additive inverse?
  • · Replies 22 ·
