What is the explanation for the varying weight readings in an elevator going up?
The discussion revolves around the varying weight readings on a scale when standing in an elevator that is moving upward. The original poster is curious about the physics behind these fluctuations, particularly in the context of acceleration and gravitational force.
  • The original poster questions how weight readings can vary in an upward-moving elevator, suggesting a misunderstanding of the relationship between acceleration and weight. Another participant explains the forces involved, noting that the support force changes with acceleration. A later post indicates an attempt to apply the net force equation but expresses confusion about the calculations.
The discussion includes attempts to clarify the concepts of weight and acceleration in an elevator context. Some participants have provided insights into the forces at play, while others are still grappling with the application of these concepts to their specific calculations. There is no clear consensus, but there are productive exchanges aimed at understanding the problem better.
The original poster's inquiry is framed within a homework context, and there are specific numerical values and equations referenced, indicating constraints related to the problem setup. The discussion reflects a mix of understanding and confusion regarding the application of physics principles to the scenario described.
zellster87
You've always wondered about the acceleration of the elevators in the 101-story-tall Empire State Building. One day, while visiting New York, you take your bathroom scale into the elevator and stand on it. The scale reads 150 lbs as the door closes. The reading varies between 120 lbs and 170 lbs as the elevator travels 101 floors.
a.)What is the maximium acceleration upward?
b.)What is the maximium magnitude of the acceleration downward?
f=mg
First of all, i don't understand how the reading on the scale can vary under their weight if the elevator is going up. It seems to me that unless the acceleration is negative, their weight should be positive throughout going up. Where is my logic wrong?
For a mass m= kg, the elevator must support its weight = mg =Newtons to hold it up at rest. If the acceleration is a=m/s² then a net force=Newtons is required to accelerate the mass. This requires a support force of F=Newtons. Note that the support force is equal to the weight only if the acceleration is zero, and that if the acceleration is negative (downward), the support force is less than the weight. If you enter a downward acceleration greater than 9.8 m/s² you will get a negative support force, showing that you must force it downward to get an acceleration greater than that of free fall.
Ah ok, I got it. Thanks dude.
What did you get as an answer
Sorry for resurrecting an old thread, but I really need the help.
I used the formula Fnet = N - Fg and still cannot get the correct answer.
I currently have ma = N - mg where m = 77.11kg, N = 756N, and g = 9.8.
So, 77.11a = 756 - 77.11(9.8)
Where did I go wrong?
Thank you for any help!
  • · Replies 22 ·
  • · Replies 24 ·
12K
12K
