Solve Triangle Pyramid Volume: V=72cm3, h=12cm
  • Thread starter Thread starter chawki
    Pyramid Volume
The problem involves calculating the dimensions of a triangular pyramid given its volume and height. Specifically, the volume is stated as V = 72 cm³ and the height as h = 12 cm. The base of the pyramid is described as a rectangular isosceles triangle.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the formula for the volume of a pyramid and attempt to derive the area of the base triangle. There are questions about the correct interpretation of the triangle's dimensions and the implications of it being isosceles versus equilateral. Some participants express confusion about the relationship between the base and height of the triangle.
The discussion includes attempts to clarify the area calculation and the properties of the triangle. Some participants have provided hints and guidance regarding the area formula for triangles, while others are exploring the implications of the triangle's shape and dimensions. There is an ongoing exploration of how to visualize and calculate the necessary dimensions.
Participants note the need for a drawing to better understand the triangle's dimensions, and there is acknowledgment of missing information regarding the height of the triangle itself. The discussion reflects uncertainty about the definitions and properties of the triangle involved.
chawki
The volume of a pyramid can be evaluated by using the equation V=1/3*A*h where h is
the height of the pyramid and A is the area of the base of the pyramid. The problem is
to design such a triangular pyramid where the volume is V = 72 cm3 and the height is
h = 12 cm. The base of the pyramid is a rectangular isosceles triangle.
a) Determine the area of the base of the pyramid. Pay attention to the unit of your answer.
b) Draw a picture of the base triangle of the pyramid in a proper scale
a)
V=1/3*A*h
A=72/(12/3)=18cm2
b) A = 18 = b*y
b=y
so: 18=2*b => b = 9cm
a)
V=1/3*A*h
A=72/(12/3)=18cm2
b) A = 18 = b*y
b=y
Your picture didn't come through, but I'm guessing your formula A = 18 = b*y is wrong. Remember the area of a triangle is (1/2)base * height. And even if it were correct, b = y wouldn't give you 18 = 2b, it would be 18 = b2. Two things to fix.
Well, I can see your picture and it isn't even of a triangle!
Did you simply misread the problem?
Yes i did :redface: my mistake, i thought it's a pyramid with 4 faces..
but then we have the area of a triangle that equal 18m2
18=(b*y)/2
To be able to draw that triangle we need to find the length of just one side (assuming the sides are equal) and the problem is..we don't have that
some please give me a hint
18=(b*y)/2
You still haven't drawn a picture of your pyramid. When you do I think you will find what you need in my earlier post. (reply #2).
i'm not good in drawing but i have an image of it in my mind..and i can't see how i will find the length of the side of that triangle
Earlier you had that V = (1/3)Ah and you are given that V = 72 and h = 12.
So A = 3V/h = 3*72/12 = 18.
You had that a long time ago. So the area of your isosceles "rectangular" triangle is 18. I presume you know what isosceles means and I presume that "rectangular" triangle means what is usually called a right triangle. And as I pointed out in post #2, the area of a triangle is (1/2)*base* height. What exactly are you stuck on, given you have all this information?
how you know that the triangle is isosceles ? isn't suppose to be equilateral ?
Didn't you read your own statement of the problem?
ok i must be blind :/
but still we can't find the dimension of that triangle..it's about the triangle and we need the height of the triangle, not the pyramid
I asked you before if "rectangular" triangle means right triangle. You didn't answer that, but I assume it does. You have an isosceles right triangle and you know its area is 18. Draw a picture of it. You should be able to figure out its dimensions from the picture.
here it is...
i guess that the base of this triangle = it's height.
Yes, and taking "s" to be the length of one of the legs, the area of the base is
[tex]\frac{1}{2}s^2= 18[/tex].
ahh ok..now i get it..
s2 = 36
s = 6 cm
and then we find the hypotenuse = approximately 8.5 cm
  • · Replies 20 ·
  • · Replies 16 ·
9K
