Circuit problem with ammeter and unknown resistance
The discussion revolves around a circuit problem involving four resistors, one of which is unknown (Rx), and an ammeter that registers zero current. Participants are tasked with calculating Rx and understanding the implications of the ammeter's resistance on the circuit.
  • Participants express confusion regarding the number of unknowns in the problem and how to derive additional equations. There is discussion about the implications of zero current through the ammeter and its treatment as a short circuit. Questions arise about the relationship between potential differences across the resistors and the identification of the circuit type.
Participants are actively exploring different interpretations of the circuit and discussing the application of Kirchhoff's voltage law. Some guidance has been offered regarding the treatment of the ammeter and the identification of the circuit as a Wheatstone bridge, but no consensus has been reached on the approach to solve for Rx.
There is an acknowledgment of the complexity introduced by the number of unknowns and the need for additional equations. Participants also note the importance of considering the voltage source in their loop equations.
  • #61
I'm stuck. I have 3 unknowns, and 2 equations. What can I try? I can try moving things around. I don't see how it helps me. I move I2R2 to equal I1r1
Great. So, now I can divide everything by...
Ah I'll just upload it. Hope you can see it clearly!
http://img221.imageshack.us/img221/9679/hopuui.jpg
But now I still have too many unknowns. 2 unknowns 1 equation! I1 and Rx in this case are the unknown.
  • #62
I like Serena said:
[edit] (You procrastinator you! :wink:) [/edit]
I'll work to crack it today :)
  • #63
Divide everything by I1?
  • #64
  • #65
  • #66
Why minus?!
ehild
  • #67
My bad, discount the minus. I was excited I was getting somewhere :P
Rx = R3R2/R1
Is that right?
  • #68
Femme_physics said:
LOL is this a mock at my procrastination? Such as I'm overthinking the theory and not doing the work? Hah. Well, I may have exaggerated in this case :)Here! Doing!
Nope! I just thought it was a funny comic! :smile:
Wait! Sorry! No it is a mock! :wink:
I was just wondering how Rx could be negative.
What could it mean?
Did you just discover negative resistors?
But that's great! We could generate voltage out of nothing! :smile:
Femme_physics said:
Is that right?
This is bizarre. I never knew you can solve a 3 unknown 2 eq thing. Is this really true? If so, what just happened here?!?
It's a special circuit that is designed to "balance" stuff.
With the method we used, we did introduce 1 unknown to many, but it didn't matter, because it would cancel out.
  • #69
Fair enough heh, I had that coming
LOL
Fixed. (as in my post above ehild!)
Is that right?
Incredible.
  • #70
How can this equation be entirely in pluses and equal zero? Unless they're all zero.
En contraire. Irht could, and is in fact, negative! Right? Because I told that you that I was going to pick Irht to be in the wrong direction (CCW), when in actuality, and from the equations we will find that it is negative the direction of I picked which is CW. All is well in the world of arbitrarily assigning currents directions to loops, alright!
Hmm...does there have to be a point in a circuit that has 0 V potential?
No, you don't have to have a point with a 0V potential. Usually you want to though, if you don't have coherent references to ground, you may end up with a circuit like this http://xkcd.com/730/
Of course, you're free to take my approach or not. In my mind the great thinking comes from realizing why you get the answer you do, why the circuit behaves as it does, and not in actually getting the answer. Hey, congrats on getting the problem right though!
Now, try using the voltage divider at the left and rightmost points, setting them equal, and solving for Rx. Once you do, you will see how wonderful keeping it simple really is. Using the voltage divider ought to take 4 minutes at most :)
  • #71
Femme_physics said:
Is that right?
You did not solve the system of equations really, I1 and I2 are still unknown. And one solution can be I1=0 and I2 =0. In this case Rx could be anything. What you got means that unless Rx=R3R2/R1 , both I1 and I2 should be zero.
ehild
  • #72
Oh yea, you do the same in mechanics. I do it arbitrary when I have 1 unknown with 1 equation. I don't like risking stuff when I have more equations or more unknown, because I figured that it may yield the wrong answer. But, if you say it doesn't in this case, then I take your word for it.
*chuckles* is that supposed to be a reference to role-playing maps/mazes?
But I get it, it's important to make a ground point.
So, if I have a simple circuit like this:
http://img153.imageshack.us/img153/333/510bw.jpg
Since the voltage drop after the 5 ohm resistor is 10, all the points AFTER the 5 ohm resistor is 0, yes?
I would be happy to do it, even if it took 44 minutes :) , but I'm not sure how to use the "voltage divider", this is the first time I hear that term. Googling it, it appears to "cut" a circuit at a point. I never realized you can do that!
ehild
Is there more for me to learn from this exercise while I can be exercising other problems, Can I just that if indeed I1 and I2 = 0 then Rx = R3R2/R1 and write that as the answer and bob's your uncle?
I can also now answer
Is the value of Rx depends on the ammeter resistance A? Explain.
No, the value of a resistor is a constant.
  • #73
Femme_physics;3310629 Is there more for me to learn from this exercise while I can be exercising other problems said:
I wrote that to people who read this thread and like to see in depth of problems.
ehild
  • #74
Ehild's comment shows his extensive knowledge and experience.
I think it also shows the answer to a trick question that he did not ask.
However, for your answer to the exercise, I think you can suffice with saying that:
Rx = R3R2/R1
A little sharper would be that we made no assumptions about the resistance of the ammeter, but that its resistance does not show in the final solution for Rx.
So Rx is indeed independent of the ammeter resistance.
Note that this question is intended to highlight the value of the Wheatstone Bridge.
  • #75
Fair enough ehild. :) I want too! As evidence by 5 pages of what you call a "simple exercise"!
  • #76
Woah, woah, have I been misinterpreted? Did I complain? I hope not! Never! Knowledge is power, it's valuable! I'll take what I can get.
I just asked if I should be investing so much in one exercise or now that I have the answer, I'll let go, for the sake my sanity, to continue other exercises :)
@ ehild. You should never have to excuse yourself for writing extra knowledge stuff. And never esp. in my threads! Am very happy you do that :)
Rx = R3R2/R1
*does victory dance!*
Awesome :) Thank you soooooooooo much everyone! ehild, Mark, ILS, gneil, quabache... hope I didn't forget anyone. Thank you! :)PS I may come back to this thread at some point as I continue to learn.
  • #77
You must have just seen circuits written in a way you're not used to. Here's a voltage divider for a circuit written the way you're used to.
The formula would be Vmiddle=R2/(R1+R2)Vbat. So the voltage across R2 will be VR2 = 2/3*12 = 8V
So really what you have in your balanced wheatstone bridge is two independent voltage dividers.
  • · Replies 21 ·
  • · Replies 31 ·
  • · Replies 31 ·
13K
