Understanding gain crossover frequency
  • Thread starter Thread starter evolosophy
    Frequency Gain
The discussion focuses on calculating the gain crossover frequency (GCF) for the transfer function H = H/(s(s² + 7s + 140)). The user initially derives the equation |H(jωGC)| = 1 and simplifies it to 400 = -ω⁶ + 280ω⁴ - (53361ω²)/4. A correction is provided, indicating the correct equation should be ω⁶ - 231ω⁴ + 19600ω² = 400. The conclusion is that there is only one real, positive solution to this equation, which represents the actual gain crossover frequency.
  • Understanding of transfer functions in control systems
  • Familiarity with Bode plots and frequency response analysis
  • Knowledge of algebraic manipulation of polynomial equations
  • Basic concepts of phase margin in control theory
  • Study the derivation of gain crossover frequency in control systems
  • Learn about the significance of poles and zeros in transfer functions
  • Explore methods for analyzing stability using Nyquist and Bode plots
  • Investigate numerical methods for solving polynomial equations
Control engineers, electrical engineers, and students studying control systems who need to understand gain crossover frequency and its implications for system stability.
evolosophy
Hello. This technically isn't homework, however I am studying for an upcoming final. I feel like I must be missing something. I'm trying to calculate the phase margin of a system so my first step is to find the gain crossover frequency (GCF).
Transfer function: [tex]H = \frac{H}{s(s^2+7s+140)}[/tex]
GCF occurs where the magnitude of the gain = 1 , or [tex]|H(j \omega_{GC})|=1[/tex] where [tex]s= j \omega_{GC}[/tex]
For the sake of brevity I'll skip most of the details of the algebra. I start with,
[tex]\left| \frac{20}{j \omega ((j \omega)^2 + 7 j \omega + 140)} \right| = 1[/tex]
By definition of GCF I'm interested only in magnitude. After factoring the 2nd order term , cross-multiplying to get 20/1, and taking the norm of each root the above equation leads to,
[tex]20 = (\sqrt{-\omega^2}) \left( \sqrt{ \left( j \omega + j \frac{\sqrt{511}}{2} \right)^2 + \left( \frac{7}{2} \right)^2} \right) \left( \sqrt{ \left(j \omega - j \frac{\sqrt{511}}{2} \right)^2 + \left( \frac{7}{2} \right)^2 } \right)[/tex]
At this point I just crank through the algebra (which I'll skip) and end up with,
[tex]400 = -\omega^6 + 280 \omega^4 - \frac{53361 \omega^2}{4}[/tex]
Finally solving for omega I get,
[tex]\omega = \pm j 0.173106[/tex]
[tex]\omega = \pm 7.80531[/tex]
[tex]\omega = \pm 14.8023[/tex]
Now we finally arrive at my problem. Plotting the original function shows the magnitude decreasing for all time. This makes sense as there are no zeros and 3 poles. So I should only have a single crossover frequency (also shown on a bode plot). So the question is how do I know which of the above values for omega is the actual gain crossover frequency?
I'm trying to solve this without the use of any plots.
Any help would be greatly appreciated! Thanks. :)
Edit: I should say that I do recognize that a negative frequency doesn't make sense so I only have 3 options and not 6. I think I can eliminate the option with the j term for the same reason. Yes, no?
I realize this is 2 years late... but better late than never right?
Your math is wrong. You should have ended up with
[itex]\omega^{6} - 231\omega^{4}+19600\omega^{2} = 400[/itex]
There is only one real, positive solution to that equation, which is the gain crossover frequency.
  • · Replies 21 ·
