Why Does My Op Amp Only Amplify by a Factor of 5 Despite Changing Resistors?
  • Thread starter Thread starter nadersb
    Amp Gain Op amp
The discussion revolves around a user's issue with an operational amplifier (op amp) circuit that is not amplifying the input signal as expected. The user reports that despite using a feedback resistor ratio intended for a gain of 150, the output is only amplified by a factor of 5. The conversation explores potential causes, including circuit configuration, component values, and the characteristics of the input signal.
  • Experimental/applied
  • The user has configured two op amps with a feedback resistor ratio of 150 but only observes a gain of 5.
  • Some participants inquire about the DC voltage at the op amp outputs without a signal input, noting that it becomes zero after a few seconds.
  • One participant suggests that the input frequency and bandwidth limitations of the 741 op amp may affect the gain, particularly with a first stage gain of 150.
  • Another participant questions the output impedance of the signal source and suggests that the first stage may function as a transimpedance amplifier.
  • Concerns are raised about the biasing of the op amps and whether the circuit is wired correctly, particularly the 4.5V bias on the positive input.
  • Participants discuss the suitability of different op amp models for the specified frequency of 40 kHz and suggest alternatives with higher gain bandwidth products.
  • There is a mention of the importance of using appropriate resistor values to avoid lowering the Q factor and sensitivity of the transducer.
  • One participant emphasizes the need to ensure proper power connections to the op amps, as miswiring can lead to output issues.
  • Another participant expresses uncertainty about what to check if the bias voltage is correct but the output remains zero.
Participants express various hypotheses regarding the cause of the low gain, but no consensus is reached. Multiple competing views on potential issues, such as wiring problems, component selection, and circuit configuration, remain unresolved.
Participants note the importance of checking connections and component values, as well as the potential impact of bandwidth limitations and input signal characteristics on the op amp's performance. There are unresolved questions about the specific wiring and configuration of the circuit.
Electronics enthusiasts, students working on op amp circuits, and individuals troubleshooting similar amplification issues may find this discussion relevant.
nadersb
hello,
I have a strange problem!
I wanted to amplify my signal and i used 2op amps, each of them has a feedback resistor between (-) pin and output( pin 2 and 6 in 741) the ratio of resistors(r2/r1) is 150, but my signal only amplify 5times! I change the R2 resistor but nothing changed! i put different resistors but all of them had the same results! I changed my op amp but still the same results! the second op amp worked perfectly but the first stage has this problem!
does anybody have an idea what's wrong with the op amp?! you can see the circuit in the link below:( the value of capacitors are 0.47uf and the first feedback resistor is not 1M it is 1.5M)
http://www.2shared.com/photo/a_JmZITS/Untitled.html
With no signal input, what is the DC voltage at each of the op amp outputs?
after a few second they become zero.
nadersb said:
hello,
I don't see anything wrong of the circuit. Basically it is powered by 9V and the +ve input biased at 4.5V midway. All stages are AC coupled so no DC offset problem to talk about.
1) First posibility is: My question is what is you frequency input to see only gain of 5. Remember 740 has gain bandwidth of 1MHz, if you have first stage gain of 150, the -3dB bandwidth is only 1MHz/150 which is less than 10KHz. The circuit talk about Ultra Sound signals, what is the frequency?
The second stage has closed loop gain of 10, the frequency response using a 741 is about 100KHz so it is very different.
Give me the input frequency before we talk more.
2) What is the output impedance of the detector/receiver at the left side of the schematic that drive the first op-amp? It is a current devices like a detector diode or photo detector? If so, your analysis is wrong. That is a current devices and the first stage is actually a TRANSIMPEDANCE amp with the transimpedance gain of 1M ohm or 1uA per volt. There is inconsistency with this theory as you change the R2 and nothing happened. But don't dismiss this just yet because it might still be a combination of bandwidth limited and detector characteristic. Please give me the kind of detector you use to be sure.
If your output becomes zero after a few seconds then perhaps your 4.5 V bias is the problem. Can you check pin 3 on both op amps and see if they have 4.5 V on them? I suspect your circuit isn't wired exactly like the diagram.
Once you are able to get a constant 4.5 V at the output of each op amp, why don't you try a gain of 15 instead of 150 and see what happens?
I use ultrasound transducer, and input signal is 40khz with 30 mv amplitude(pick to pick)
there is a 33ohm resistor parallel with it as you see in the image that i have sent.
what if I change the op amp, and try different model that is compatible with this frequency?! do you have any suggestion which model would be suitable?!
I double checked my connections, and I don't think that (+) pin's bias has any problem, but I will check it again and I will inform you ;)
How did you decide on 33 ohms? What happens to your gain if you replace it with 100k ohms? What values are your capacitors? If your signal is 40 kHz, try using a 270k feedback resistor for each op amp.
because we use signal generator instead of transducer most of the time and its resistor is 50 ohm so we chose a resistor that is near to 50 ohm .
each capacitor is 0.47uF.
I didnt change the value of input resistor, I will change it and inform you what happens;)
I understand now about the 33 ohm resistor. Still I would prefer a value of 100k or higher at least when using a transducer. The lower the value, the more it will lower the Q and sensitivity of the transducer. A gain higher than you need can cause the op amp to oscillate if the right phase shift occurs. A good rule of thumb is that 60 dB of gain is the most you can achieve on the same board at the same frequency. It is possible to get positive feedback through the power supply, ground or other connections with gains that high.
It still is important that you have 4.5 V at the output of each op amp with no signal in.
I don't see 33ohm, can you double check, I cannot see the entire picture of the signal detector.
40KHz is too high for 741 with gain of 100. Maybe try something like OP-37 or others that has higher gain bandwidth product. But I think you have bigger problem than that.
Did you say you read 0V at the output of the both op-amps(pin 6)? If so, that is wrong, you should get 4.5V on both. I think Skeptic2 is doing a good job helping you, I don't think you need two people telling you what to do. Good luck.
I will check pin 3, but what if pin 3 is 4.5?! what else could be the problem for zero output?!
and last thing sir, what do you mean by "bigger problem"?! what is it?!
thank you
i know this sounds dumb but ---
National Semconductor's engineers used to field this problem so often they put it into an application note...
"how to" schematics usually don't show power connections to the IC
and often newbies don't connect power because it's not shown
and i notice that circuit linked doesn't show power to pins 4&7
and it's easy to mis-wire a round can opamp when you're looking at it from the bottom and using a top view wiring diagram
http://en.wikipedia.org/wiki/File:LM741_Pinout_Round.svg
dont be offended by this dumb question its just i have no idea as to your level of expertise.
i'm not offended if you ignore this post. You can even resent me it's okay.
lastly what is your source for 9V?
If it's a small battery place a few microfarads across it - reason is opamps demand a low-impedance power supply which a BL006P battery is not.
as yungman observed skeptic is doing a good job with technical advice.
but I don't mind asking the real dumb questions.
hope it doesn't offend you guys
and i won't meddle further
old jim
:D
dont worry I connected 7 and 4 to Vcc and ground;) I am working with a Dc voltage source.
I will be thankful for your ideas ;)
thank you
What I meant is you have some basic wiring problem. You should get 4.5V at the output on both of the op-amp. If it float to 0V, something is very wrong. I suggest you check your wiring and check for cold solder joint. Get the 4.5V on both output before you worry about the gain. Measure pin 3 is 4.5V, pin 2 should follow pin 6 because output is connect to pin 2 through R2.
Measure and verify pin 7 is 9V and pin 4 is 0V. After you get the correct DC reading, if Skeptic is not around, I'll keep helping you.
I checked it today and pin 6 is around 4.5 in both op amps;) so this problem is solved;) I also changed the input resistor( 33ohm) and it worked, I mean when I used 33ohm ac voltage of pin 2 was about 10 mV pick to pick but now we have much more better signal and its about 25pick to pick, so thank you for your suggestion, but I didnt change the op amps yet, when I do it I will inform you;)
thank you
With the new values how much signal are you getting out of the op amps?
about 4 V pick to pick, but the problem is we amplify noise too, and i think we should add a filter to our circuit!
thank you
I really don't understand what is pick to pick! When the op-amp is working, you really should not see any signal on pin 2. It is a summing junction. What I want you to tell me is what is the input to R1, what is the output at pin 6 of the first op-amp.
If your input frequency is 40KHz, if you are using 741 of gain bandwidth product of 1MHz, the -3dB point is about 10KHz. Above 10KHz, the gain will roll off at 6dB per octave. 40KHz is two octave above 10KHz, so your gain will go down 12dB which result of a gain of 25 instead of 100. This mean if you have 1mV at the input of R1, you will have 25mV at pin 6 of the first op-amp.
I do not see the 33ohm in your diagram, so I don't know that part. One thing is the way your circuit is, you are assuming that the output impedance of the detector is very low impedance. If the output impedance is high, your gain is
[tex]A_{cl}=\frac{R_2}{R_1+R_{det}} \;\hbox { instead of }\; \frac {R_2}{R_1}[/tex]
So the whole thing is not as simple as you think. First you have to show me what kind of detector you use as I asked on my first post. And show me the complete circuit where is the 33ohm.
What I fail to understand is why we haven't switched to a better op-amp than the 741. Get a good op-amp and then switch back and forth. It will be a good lesson on frequency response.
I am not convinced that he is really running a gain of 100. I need to see what kind of detector first as a lot of these kind of detectors are current output and you cannot look at it as a voltage source. Yes, I think OP37 will work a mile better than 741. I am sure there are newer and better ones as I used OP37 like 20 years ago. It is a much lower noise amp also design for higher close loop gain. I want to make sure his circuit is really doing what it supposed to do before sending him out to buy another op-amp.
would it be meddling to offer a simple, non-intrusive test?
I said i wouldn't meddle
but old troubleshooters habits die hard.
I always check the dumb things first - it's less embarassing to find them one's self.
And if it's not one of the dumb things, well, you don't have to admit to anybody that you were dumb enough to have looked.
so here's something you can check quietly
>>Reasoning:<<
As Yungman and Skeptic observed, 741 is not a real fast opamp.
it is asking a lot of the 741 to amplify 40 khz by gain 150
though by datasheet it looks like it should do it
1 volt sinewave at 40 khz has dv/dt of 0.25 v/usec
and you are trying to make 15mvX 150 = 2.25 v
which is dv/dt of 0. 565 v/usec
National's datasheet
http://www.national.com/ds/LM/LM741.pdf
near bottom of page 3
states 741 'slew rate' is 0.5 v/usec
so you're using it all
but that datasheet is written for +/- 15 volt supply not your +/- 4.5
Your 741 might be short of "oomph" at reduced supply
see this appnote
http://www.national.com/an/LB/LB-19.pdf
bottom of page 1:
"The slew rate limit is the maximum rate of change of the amplifier’s output voltage and is due to the fact that
the compensation capacitor inside the amplifier only has finite currents available for charging and discharging...
..For example the full-power bandwidth of the LM741 with a 0.5V/μs Sr is approximately 6 kHz ..."
At your reduced power supply voltage, you may be just asking too much of it --
>>Suggestion:<<
You could test that thought by simply raising your power supply to 30 volts while watching output with an o'scope
if it doesn't help - you don't have to admit you looked.
But either way you'll learn whether "Slew Rate" is affected by supply voltage.
old jim
Not meddling, the more the merrier!:approve:
Nadersb, so you're getting 4 V peak to peak out with the signal generator set at 30 mV and with 25 mV at pin 2 of the op amp. Is that 4 V using both op amps or just one?
You should check the power supply for noise. The noise may disappear once you start using the ultrasonic transducer. It in itself acts as a pretty good filter. If that's not enough, there are some pretty good active filter circuits that will also give you gain.
Mr.yungman, sorry about the pick, I meant peak;) it was mistake!
I am working with an ultrasonic transducer( I attach the picture of it)
about 33ohm: do you see the resistor that is parallel with the transducer?! that is 33ohm, but after mr.skeptic comment I changed it to 100k.
Am I answer all of your questions sir?!
thank you for your attention
mr.avreagesupernova, I am busy these days so I couldn't buy new op amps, but I will on saturday;)
mr.jim hardy, thank you I will test it;)
You mean the one in parallel with not value or refence? Yes it's better to change to 100K, don't make sense to be 33 ohm.
Is this from the output of the first amp like skeptic asked? Tell me the output of the first amp. What is the value of R1 and R2 now to make sure. If the R2 is still 1.5M, I want you to change to 150K and report back how much pick to pick do you get on the first stage.
The reason I ask is because after I reduce the gain by 10 times, you should get the full response. From that, I can back calculate what is the output from your detector. In turn to make sure the amp is not frequency limited.
You should not get a lot of noise from the electronic. The gain is only 1000, even 741 is reasonable. But if you change to OP37, it is a much lower noise amp. But if the noise is from the detector input, then you might have something elso going on.
"""about 4 V pick to pick, but the problem is we amplify noise too, and i think we should add a filter to our circuit! ""
see figure "voltage swing vs supply voltage " on page 4 of this link:
http://www.national.com/ds/LM/LM148.pdf
it's the datasheet for quad 741 and it has all the good ol' information that used to be on single 741 datasheet. Print a copy to share with your colleagues.
What that graph shows is that opamps need "headroom"
that is, they only guarantee it can drive output within about two and a half volts of supply,
so with 9 volt supply and 2.5 v headroom at each end the output might only swing about 4 volts peak to peak ...
25 millivolts p-p at inverting input?
well it's sure not holding summing junction at zero.
which could be from lack of headroom
or lack of slew rate
or scope probe capacitance upsetting amplifier
or simply out of gain
might you be overdriving it in attempt to get full output ?
I think Yungman is on to something...
see same datasheet page 5 figure "Open Loop Frequency Response" top right of page...
...at 40 khz it's only got open loop gain of ~30 db = gain of 31.6 if i remember logarithms
with open loop gain of 31 , i wouldn't expect a higher closed loop gain of 150
so i repeat - if you're using an adjustable bench supply, do a quick gain check at higher supply voltage to look for headroom and slew rate limiting
and if you're using a signal generator do a quick gain check at 400hz then 4khz to look for frequency response limiting.
and be aware it's generally risky to connect test equipment to the summing junction particularly if feedback resistance is large.
Glad to see somebody is really bujilding stuff instead of simulating it.
congratulations, sir.
old jim
  • · Replies 31 ·
  • · Replies 20 ·
