Heat equation solving quadratic equation with complex numbers
The discussion focuses on solving the quadratic equation derived from the heat equation, specifically the equation kλ² - ρcp u λ - ρcp ωi = 0. Participants utilized the quadratic formula, resulting in the expression λ = α + iβ ± γ√(1 + iδ), where α, β, γ, and δ are defined in terms of ρ, cp, u, k, and ω. The solution provided indicates that γ = (ρcp/2k) and δ = (4kω/ρcp²), with clarification that α = ρcp/(2k) and β = 0, aligning with the required format.
  • Understanding of quadratic equations and the quadratic formula
  • Familiarity with complex numbers and their properties
  • Knowledge of the heat equation and its physical significance
  • Basic algebraic manipulation skills
  • Study the derivation of the heat equation in thermodynamics
  • Learn about the application of complex numbers in engineering problems
  • Explore advanced topics in quadratic equations and their applications
  • Investigate numerical methods for solving differential equations
Students in physics or engineering, mathematicians dealing with complex equations, and anyone interested in the application of quadratic equations in real-world scenarios.
dp182
given that kλ2-ρcpuλ-ρcpωi=0
plug into the quadratic formula and get out an equation that looks like this
λ=α+iβ±γ√(1+iδ) where α,β,γ,and δ are in terms of ρ,cp,u,k, and ω
(-b±√b2-4ac)/2a
2-ρcpuλ-ρcpωi=0
λ=α+iβ±γ√(1+iδ)
so I plugged it in and came out with
(ρcpu/2k)±(ρcpu/2k)√1+(4kωi/ρcpu2)
so γ=(ρcpu/2k) and δ=(4kω/ρcpu2)
but I'm unable to make the first term α+iβ and help would be great
(-b±√b2-4ac)/2a
2-ρcpuλ-ρcpωi=0
λ=α+iβ±γ√(1+iδ)
Should be λ= (ρcpu/2k)±(ρcpu/2k)√1+(4kωi/ρcpu2) since you are solving the quadratic equation for λ. Note that I didn't check your work.
They're not asking you to make the first term α+iβ, just that you have an equation that has the form they give. In what you have, α = ρcpu/(2k) and β = 0.
  • · Replies 22 ·
