What Is the Maximum Speed a Car Can Travel Without Skidding on a Circular Track?
A 1000-kg car on a 50-m radius level track can travel without skidding by utilizing the coefficient of static friction of 0.80. The normal force is calculated using Newton's second law, resulting in a value of 9810 N, but with the gravitational constant set to 10 N/kg, it adjusts to 10000 N. The static friction force, which prevents skidding, is determined to be 8000 N. To find the maximum speed, the radial component of Newton's second law is applied, ensuring the friction provides the necessary centripetal force. The discussion emphasizes the importance of following the outlined steps and using free body diagrams for clarity in solving the problem.
albarnett17
Physics lab normal force please help!
A 1000-kg car moves at a maximum speed so that it does not skid off the 50-m radius level track. If the coefficient of static friction between the road and wheels is 0.80. What is the maximum speed? Assume that the gravitational constant is 10.0 N/kg =10.0 m/s. Use the simulations in 4.5 Car Circles a Track to check your answers.
Write an equation for the vertical y-component form of Newton's second law. Determine the magnitude of the normal force. Then use a force law equation to determine the magnitude of the static friction force.
Write an equation for the radial component form of Newton's second law. Use this to determine the maximum speed that the car can travel so that it does not skid (so that friction can provide the needed force to keep the car moving in a circle). Once you have calculated the maximum speed adjust the speed slider in the 4th simulation to this speed and see if the car stays on the track.
welcome to pf!
hi albarnett17! welcome to pf! :wink:
with these questions, do everything in the order the question tells you to
start with …
… what do you get? :smile:
Idk any equations or where to put what in the equations i have no idea how to do this.
in other words:
draw a free body diagram
mark all the external forces on it
then do F = ma in the vertical direction​
Ok i did i have a diagram but i still don't get sorry but i really do not kno like almost anything in physics
ok, now we have to do F = ma vertically (in the y direction), from your diagram
a (acceleration) vertically is obvously zero, and your only vertical forces are the normal force N, and the weight (which you're calling V, but we usually call it W) …
ok so what is the equation (with the numbers in)? :smile:
F=10000*0
f=0
what's F?
f= 0
yes, but what is F made of?
Force idk m*g
albarnett17 said:
Force idk m*g
m*g = 0 ? :confused:
im so confused man here's what i got for
question 1.F(n) = mg
F(n) =(1000)(9.81)
F(n) =9810 N
SF=UF
SF=(0.80)(9810)
Sf=7848
hi albarnett17! :smile:
F(n) =(1000)(9.81)
F(n) =9810 N
SF=UF
SF=(0.80)(9810)
Sf=7848
ok so far :smile:
(except thequestion says g=10 N/kg, so the friction force is 8000 N)
now use that in F = ma for the x direction :wink:
