Washing machine motor soap extruder
The discussion centers on using a washing machine motor to drive a soap extruder for a small home business. The user seeks advice on the viability of this approach and inquires about the appropriate screw and barrel sizes, suggesting a preference for 30mm or 40mm diameters. The user also needs guidance on the motor's power specifications and gear ratios to provide to the screw and barrel manufacturer. The consensus indicates that a washing machine motor can be a cost-effective solution if the correct specifications are met.
  • Understanding of soap extrusion processes
  • Knowledge of screw and barrel specifications
  • Familiarity with washing machine motor capabilities
  • Basic mechanical fabrication skills
  • Research the specifications for 30mm and 40mm screw and barrel combinations
  • Learn about the power requirements for washing machine motors in extrusion applications
  • Investigate gear ratio calculations for optimal motor performance
  • Explore DIY fabrication techniques for building custom extrusion machines
Entrepreneurs starting a soap-making business, hobbyists interested in DIY extrusion machinery, and individuals exploring cost-effective manufacturing solutions.
techguy2000
Hello
I am trying to start a small home business making soap. I am on a really tight budget and also very new to the extrusion process.
While I may be extruding soap, I understand that the process is very similar to plastic extrusion.
I want to extrude soap bars using a machine similar to the soap extruder on this website
http://soaptec.biz/products_dp_finesextruder.html
However I am trying to make this as cheaply as possible.
I plan on buying a screw and barrel and then fabricating the rest of the machine myself.
I am thinking of using a washing machine motor to drive the screw.
Could you please advise me on the viability of this?
What size screw and barrel would I need to order from the supplier? I was told that a 30mm or 40mm screw would be best, a 100mm screw would require too much power and would be too expensive.
Would a washing machine motor be suitable?
The manufacturer of the screw and barrel asked me what power motor would be used and what are the gear ratios. What should I tell him? I have not told him that I plan to use a machine motor :smile:
Any advice would be greatly appreciated
Thank you
Tell him the power of the motor and what rpm you plan on running the screw at...
  • · Replies 19 ·
10K
48K
