Now what is Aharonov-Bohm really?
  • Context: Graduate
  • Thread starter Thread starter nonequilibrium
    Aharonov-bohm
The discussion centers on the Aharonov-Bohm effect, exploring its mathematical formulation and implications within quantum mechanics. Participants seek clarity on the role of the vector potential and phase shifts in wavefunctions, particularly in the context of charged particles in magnetic fields, and how these concepts relate to observable phenomena.
  • One participant expresses confusion over the explanation of the Aharonov-Bohm effect, particularly regarding the phase of the wavefunction and the implications of different paths leading to different phase contributions.
  • Another participant suggests a concrete approach by solving the Schrödinger equation for a charged particle in a magnetic field, indicating that the energy eigenstates are affected by the magnetic flux, despite the absence of a magnetic field at the particle's location.
  • A participant references the importance of position-dependent phase in gauge theories, arguing that this does not imply the phase is ill-defined but rather highlights its dependence on the vector potential.
  • One participant draws an analogy to a double-slit experiment, suggesting that phase shifts can be introduced similarly to how they are manipulated in photon experiments.
  • Another participant supports the previous claims, emphasizing that the energy states depend on the magnetic flux, which is an observable quantity, despite the electrons not entering the region with a non-zero magnetic field.
Participants express varying degrees of understanding and interpretation of the Aharonov-Bohm effect, with some proposing concrete mathematical approaches while others remain uncertain about the implications of phase shifts and the role of the vector potential. No consensus is reached on the clarity or completeness of the explanations provided.
Some participants note that the discussion relies on specific mathematical formulations and interpretations that may not be universally agreed upon. The implications of phase shifts and the definition of the vector potential are highlighted as areas of potential confusion.
nonequilibrium
I can only seem to find vague sources explaining Aharonov-Bohm, usually saying things as "the different paths of an electron interfere". I presume this is language borrowed from a Feynman path integral formulation of QM, but I'm not familiar with that yet, so I'd rather see it explained in "ordinary" QM math.
Some sources seem to suggest that the basic consequence of a vector potential is that the phase [itex]S[/itex] of the wavefunction [itex]\psi(\mathbf r,t) = R(\mathbf r,t) e^{iS(\mathbf r,t)}[/itex] gets an extra term, namely the path integral [itex]\int_{\mathbf r_0}^{\mathbf r} \mathbf A(\mathbf r') \cdot \mathrm d \mathbf r'[/itex] (where [itex]\mathbf r_0[/itex] is some arbitrary reference point). Then again, this can't really be true, cause then phase wouldn't be well-defined (since a different path, but also going from r_0 to r, could give a different result). I realize that this last remark is also the key concept in the AB effect, but still, not in the aforementioned way, right? After all, phase shouldn't be ambiguous (except for a 2pi multiple of course). Actually, it's exactly this argument (that different path integrals should give the same phase mod 2pi) that is used to argue flux quantization in a superconducting ring... So why does it not apply more generally?
As you can see, I'm a bit confused. Note that I'm not looking for a vague explanation, I'm looking for something concrete (and well-defined) mathematically. Thank you!
One concrete thing you can do easily in the regular Schrödinger wave equation formalism is solve for the energy eigenstates of a charged particle confined to a circular 1D ring through the center of which a solenoid passes carrying some amount of magnetic flux. There is no B-field at the ring's radius, but there is an A-field. Write down the Schrödinger equation including the A-field and solve it. Once you figure out what 1D Schrödinger equation to write down, you should find that the solutions are almost as trivial as free-particle solutions. You should find that the energy eigenstates of the particle are shifted by the presence of the magnetic field, even though the particle cannot enter the B-field. Furthermore (as I recall) the clockwise- and counter-clockwise-moving energy eigenstates cease to be degenerate. This is one manifestation of the Aharonov-Bohm effect.
Not sure if this is helpful, but it is concrete and mathematically well-defined.
As with most aspects of "ordinary QM", Ballentine is a good place to start.
Try section 11.4.
[...] this can't really be true, cause then phase wouldn't be well-defined (since a different path, but also going from r_0 to r, could give a different result).
This doesn't mean the phase is ill-defined. It just means the phase can be position dependent -- which is also a key concept in gauge theories of interaction.
Take a look at Ballentine and then see if any points remain unclear...
The setup is similar to a double-slit with photons, where you can add phase shifts at the slits (e.g. with material with a different refractive index). Similar to this, you have to constrain the electron path in order to get a phase which is nearly the same for all electrons in one path.
I also back up the approach proposed by The Duck.
You will find that the energy states depend on the magnetic flux through the loop which is an observable in contrast to A.
Nevertheless this is astonishing given that the electrons don't enter the region where B is non-vanishing.
  • · Replies 171 ·
19K
  • · Replies 17 ·
