Why use primed coordinates for this
  • Thread starter Thread starter aaaa202
    Coordinates
Griffiths uses primed coordinates in his notation to clearly distinguish between the point where the potential is calculated and the location of the charge distribution. The integration element, dl', is primed to avoid confusion with unprimed coordinates, which could be misinterpreted as referring to the same point. This distinction is crucial for accurately representing the electrostatic potential of a charge distribution. The notation helps clarify the relationship between different points in the integration process. Overall, the use of primed coordinates enhances clarity in mathematical expressions.
aaaa202
Griffiths notation kind of bothers me. Can anyone explain why he uses primed coordinates in the attached picture. Wouldn't dl, da, dτ do just as well?
Cheers :)
I hate books that are so sloppy in their notation :-(. What he wants to write is
\Phi(\vec{x})=\int \mathrm{d}^3 \vec{x}' \frac{\rho(\vec{x}')}{4 \pi |\vec{x}-\vec{x}'|},
which gives the electrostatic potential of a (time independent!) charge distribution \rho (in Heaviside-Lorentz units). Note that there are two points involved: First there's the point \vec{x} at which the potential is calculated and the point \vec{x}' which is at the location of a charge \rho(\vec{x}') \mathrm{d}^3 \vec{x}'. Then you "sum" (integrate) over all these charge elements.
But why dl'? Is that because you might misinterpret dl unprimed as dl along the vector r (can't find that damn script letter)?
You integrate over primed coordinates so the integration element ( dl') is primed too. In vanhees71's notation, d3x' is an infinitesimal volume at point x'. For the 1D case, dl' is an infinitesimal length at point r'.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
