PNP transistor and argument with my teacher
The discussion revolves around the interpretation of voltage in a PNP transistor circuit, specifically the application of Kirchhoff's Voltage Law (KVL) and the sign convention for the base-emitter voltage (VBE). Participants explore the implications of these conventions on circuit analysis, with a focus on a specific test question and the disagreement between a student and their teacher regarding the correct approach to the problem.
  • One participant argues that VBE should be treated as a voltage drop, leading to the equation 6 - ReIe - 0.7 = 0, while their teacher insists it should be treated as a positive voltage source.
  • Another participant suggests that the misunderstanding may stem from differing interpretations of VBE, noting that it represents the voltage from emitter to base and is negative in this context.
  • Some participants clarify that the sign convention for VBE could be either VB - VE or VE - VB, leading to confusion about how to apply it in KVL equations.
  • There are discussions about the implications of using different sign conventions and how they affect circuit analysis, particularly in relation to PNP and NPN transistors.
  • One participant emphasizes the importance of consistency in using voltage drops versus voltages at circuit points, pointing out that the voltage across the base-emitter junction is -0.7 volts while the voltage at the emitter is +0.7 volts relative to ground.
  • Another participant expresses confusion about how to apply the sign conventions in KVL, questioning whether their original approach or the teacher's was correct.
Participants do not reach a consensus on the correct treatment of VBE in the KVL equation. There are multiple competing views regarding the sign convention and its application, leading to ongoing debate and uncertainty.
Participants note that different conventions may exist in various fields of science and that assumptions about conventions should be verified based on context. The discussion highlights the potential for confusion when different sign conventions are applied in circuit analysis.
Femme_physics
I just had arguments with my teacher about my test answer in class. I'm a little upset, but maybe I'm acting like a spoilt brat (I'll be the first to admit it) I went out and I'm using a hallway computer in my college so I can't post images. I still disagree with him-- But I'll try to explain it as best as I can.
Say I have a PNP transistor. I have a source of 6 volts. I have an unkown resistor RE, and a currect Ie = 1.2 mA. I am also told that VBE = -0.7 volts. VBE is connected to the ground.
THE FOLLOWIG IS A DRAWING OF ONLY THE LEFT SIDE OF THE CIRCUIT6 volts ----/\/\/\/\/\-------(EMITTER--->BASE)----GROUND
(the jagged lines describe the resistor RE)
Consider the right side of it (with the collector) irrelevent. Both me and my teacher did.
So, in the solution, can I just do:
Sum of all voltages= 6 - ReIe - 0.7 = 0
5.3 = 0.0012 x Re
Re = 4416.6 ohmsBUT my teacher say I should write VBE in plus in my equation! That since it's been defined as -0.7 volts, it's a mistake to write it in minus in the equationBut that doesn't make sense to me. Vbe is supposedly an electrical component, not a voltage source. There must be a voltage drop there, it can't act as a votlage source!
Please help me see the light!PS If anyone could tell me with explanation who is wrong and who is right (his explanation that it can act as a voltage source is weird to me!) he should still be in class in the next 2 hours...otherwise I'll talk to him next week
Hey Fp! :)
Looks to me like a misunderstanding.
What you write looks correct to me.
Indeed the transistor is not a voltage source and you'll have voltage drop from E to B.Apparently VBE is the voltage from E to B, which is negative.
If you write it down as a formula, you should have:
ƩV = +6 - ReIe + VBE​
Note the plus in front of VBE.
Is that perhaps what your teacher meant?
Did you perhaps write this down with a minus in front of VBE?If you fill in the number for VBE, you get:
ƩV = +6 - ReIe - 0.7​
which is what you wrote down and which is correct as far as I can tell from this.(Btw, VBE in a similar situation with an NPN transistor would be +0.7 V.)
Do you mean diagram 1 or 2 in my sketch?
As you have described it the transistor would burn out.
Let's stick to just PNP - how come you set it as plus, but plug it in minus? And how come in NPN it is plus?
A pn junction will conduct for Vnp > 0
A np junction will conduct for Vpn < 0
Hint: You will also have to think about the polarity of your power supply and about sign conventions for currents.
Diagram B
As I understand your description, you have the following diagram:
Is that what you intended?
Correct ILS, plus the the fact that current Ie flows downwards from the resistor ( as it should be ) and equals 1.2 mA
Could you elaborate please?
Okay, okay. I added the current. :)
What about my earlier post?
I read your earlier post wholly through and replied to it. Its right under Studiot's first post
OK, taking ILS diagram now makes sense
Vbe = -O.7 means The Vb - Ve = -0.7
that is (0) - (+0.7) = -0.7
Which is as it should be.
@ Studio - So in KVL you plug it counts as addition to the 6 volts like my teacher proposed?
Oops. I didn't recognize it as an answer to my post. :blushing:
Femme_physics said:
Let's stick to just PNP - how come u set it as plus, but plug it in minus?
This is about sign conventions.
VBE could be either VB - VE or VE - VB.
From your context I deduce that the sign convention your teacher is using is that:
VBE = VB - VE
With VB = 0 [V] and VE = +0.7 [V], it follows that VBE = -0.7 [V].
With this sign convention, since you already know that in your formula you need -0.7, you need to plug in VBE as "+".
Using the same sign convention, in a similar NPN circuit you have:
VBE = VB - VE = 0.7 [V] - 0 [V] = +0.7 [V]​
That is, Vb must be higher than Ve (contrary to a PNP transistor).
If you got that, good, because my next statement may make sense and may not. Tell me if it doesn't.
You are mixing up voltages measuresd across a component with voltages appearing at particular points in the circuit.
The voltage across the base emitter is -0.7 volts (because the transistor is pnp)
but the voltage at the emitter is +0.7 volts in relation to the circuit reference.
You have to decide if you are going to use voltage drops or voltages at circuit points and then use them in a consistent manner.
Obviously the voltage drop = difference between the voltages at two points.
However we normally count this positive going up the circuit and negative going down.
Are you still with me?
I was referring to the fact that pnp circuits often have negative supply, so ground is the highest potential.
And, as the others have pointed out, Vbe = -Veb
ILS - in ur first post u said I was correct, now from what I read out you say I'm wrong... Originally you said I write it in plus in KVL but plug as minus... I get your voltage explanations of VBE = vb - ve ... What i don't get is how I plug it in the formula for a KVL loop where i denote the voltage drops... Up till this day, all my voltage drops were minused UNLESS it was an opposite voltage source or the current was flowing the opposite direction. I'm still confused of whether I did right or not...or whether my teacher was correct. Ill get home in 15 mins and i could use my scanner... I want to get to the bottom of this so i will be more thorough and post the original exercise with my full solution. I am on the bus with 15% iphone battery so it might die any moment. Talk to u guys soon from my headquarters
What you wrote in your opening post is all correct.
I already said it might be a misunderstanding with your teacher.
What formula exactly did your teacher disagree on?
I would be interested, where have you seen the second 'convention'.
I have only ever seen 'first minus second' in electrical circuits.
This is then consistent with the zero referenced node voltages
thus Vb = V at b minus zero and is positive if Vb is more positive than zero.
I would imagine the other convention to be a nightmare to work with.
As you know, I'm not an electrical engineer.
So I can't say for sure if the second convention is used in electrical engineering.
I'd have to research it to find out.
(But I find it hard to believe that all electrical engineers world wide use the same convention.)
I do know that in different fields of science different conventions are used and also that different conventions are used in the same field.
I have learned to always check which convention is used and not assume anything.
Often the convention must be deduced from the context.
As for other scientific fields with a different convention, the first that springs to mind is vector algebra:
##\vec{AB} = \vec B - \vec A##.
Finally home.
I can scan and write in more details.
Let me start with the replies:
I have also always only seen the "first minus second convention"
I believe so. If I get to choose though whether I'm going to use voltage drops or voltages at circuit points (I believe we did the latter when we just started studying electricity) I prefer to choose voltage drops-- seems faster. You said "You are mixing up voltages measuresd across a component with voltages appearing at particular points in the circuit."
Not really. I know for sure that the voltage drop FROM ve to the ground is 0.7. Whereas Ve must be 0.7 and Vground = 0 ... I know what every point equals to. I reckon.
Oh yes, duly noted that.
I'm not sure which misunderstanding.
Let me be as clear as I can be, I have the scanner so let's start with the ENTIRE exercise:
http://img403.imageshack.us/img403/2739/theexercise.jpg
My full solution (and my teacher solution below it):
http://img502.imageshack.us/img502/5513/solutionstuff.jpg
Not really.
That's good
You need voltage drops for KVL so you have to perform subtractions if you calculate these drops from the circuit voltages at circuit nodes. It is important to keep a consistent direction for these.
I see you are studying the common base configuration.
I hope i´m not heaping confusion on confusion, but:
Kirchhoff can be done in two ways: Voltage drops negative and sources positive
or the other way round (see: http://en.wikipedia.org/wiki/Kirchhoff's_circuit_laws).
And then U=RI and current direction and sign conventions come in.
Let me keep it simple: your solution is correct and what you wrote down as your teacher's proposal is wrong.
Femme_physics said:
It's soundproof logic!
Yep! :smile:
And it matches with the convention that VBE = Vb - Ve.
Studiot, maimonides, just to make it more than official-- do you also agree with ILS that I was right and my teacher was wrong? I argued with my teacher in class for 20 minutes! And then after class for another 15 minutes!
I like Serena said:
Yep! :smile:
As it should be!
Your drawings in posts 21 and 25 are perfectly ok, as far as I can tell anything at all.
Thanks, maim. Studiot?
Your value for Re and analysis are correct. There is a forward voltage drop across both the emitter resistor and the emitter base junction for Kirchoff purposes.
I would not use K myself, however. Just a simple voltage divider. Then the issue would not arise.
Well done.
  • · Replies 19 ·
  • · Replies 22 ·
18K
