Temperature coefficient of resistance calculation
The discussion revolves around the calculation of the temperature coefficient of resistance (α) using different formulae. Participants are exploring the context in which each formula is applicable and the reasoning behind their usage.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants are comparing two formulae for α and questioning when to use each. Some express confusion over the applicability of the formulas, particularly when different temperatures are involved. Others discuss the derivation of the formulas and their linearity.
The discussion is ongoing, with participants sharing insights and seeking clarification. There is a mix of agreement and disagreement regarding the correctness of the derivations and the conditions under which each formula should be applied.
Some participants note that the formulas may yield different results depending on the temperature range considered, and there is mention of specific temperature values (e.g., T1 = 0°C and T1 = 20°C) affecting the choice of formula.
Preksha
When we are supposed to calculate the value of "temperature coefficient of resistance " i.e. α , how are we supposed to choose between the following two formulae :
α = (R2 - R1) / (R1*T2 - R2* T1 )
or
α = (R2 - R1)/ [ R1 *( T2-T1) ]
I have attached scanned pictures of two similar questions . I can't understand as to why diff. formulae are being used in both of them
I am new to this forum, so I have no idea as to how things work here. I wanted to know, till when , can I expect a reply to my question?
Its not a linear function.
http://img405.imageshack.us/img405/9383/co3wv.jpg
Preksha,
My physics book agrees with this link, which is a different formula than what you submitted.
Ratch
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/restmp.html
Ratch said:
Preksha,
Ratch
My second formula is the same as yours.
The first one can be derived as
R1 = R0(1 + aT1) ...(i)
R2 = Ro (1 +aT2)... (ii)
Divide (i) by (ii)
And you'll get the 1st formula.
Both formulae are correct.
The difference in their usage is that When T1 is 0deg. The 1st formula changes to the second one. But when I came across this particular question where T1 =20 deg (the one I've posted before) and still they are using the second formula, i got thoroughly confused. So, if you have any idea, please help.
I didnt get you :O How does linearity play a role in this question?
Does anybody else know how to go about it?
Preksha,
or
Use the one that is correct. The second formula agrees with the link I posted, so use that. The first formula can be arranged to R=Ro(1+αT)/(1+α*To). Does that make sense compared to the first formula, which is R=Ro(1+α(T-To))?
Yes, that is the correct one.
Divide (i) by (ii)
Your derivation is wrong. R1 = Ro(1+α(T1-To))
They both can't be correct.
In order for the formula to be correct, it must be correct across the whole temp range, not just one temperature. Use the one proven to be correct.
Ratch
Hello Preksha. Welcome to PF !
Be patient. While you're waiting, read the rules for this Forum, particularly the section regarding Homework Help.
Rules
