What, physically, are the Miller planes of a crystal?
  • Context: Graduate
  • Thread starter Thread starter Roo2
    Crystal Planes
The discussion centers around the physical interpretation of Miller planes in crystallography, particularly in relation to diffraction phenomena. Participants explore the nature of these planes, their representation in real space versus reciprocal space, and their relevance in the context of complex structures like proteins.
  • One participant expresses confusion about the physical existence of Miller planes in complex structures, contrasting them with visible features of diffraction gratings.
  • Another participant explains that Miller indices represent a vector perpendicular to the Miller plane, defined using lattice vectors, and suggests that these planes can be visualized in 3D space.
  • Some participants propose that Miller planes can be understood as real space planes that correspond to reciprocal space, while others question the physical implications of mathematically defined planes.
  • A hypothetical scenario is presented where the phase changes of waves reflecting off two particles can be related to Miller planes, suggesting that these planes can influence the constructive interference of waves across a lattice.
  • One participant shares a mnemonic for identifying Miller indices based on counting atoms in a crystal structure, providing a method to visualize the planes.
  • Another participant reiterates the difficulty in conceptualizing these planes in the context of complex protein structures, emphasizing the need for clarity on their origin.
  • A later reply notes that the planes are associated with the lattice formed by many protein molecules rather than individual molecules.
  • One participant dismisses the concern about the physicality of the planes, suggesting that it is merely a convention.
Participants express a range of views on the nature and physicality of Miller planes, with some agreeing on their mathematical representation while others remain uncertain about their real-world implications, particularly in complex structures like proteins. The discussion does not reach a consensus.
Participants highlight limitations in understanding the physical manifestation of Miller planes, particularly in complex molecular structures, and the dependence on definitions and conventions in crystallography.
Roo2
I'm trying to learn crystallography and I've had trouble with this concept since the very beginning of the course. It's been so long since it's been introduced that I'd be embarrassed to ask the prof. Right now, I seem to understand the principles of diffraction based on the Miller model; that is, based on the phase changes of radiation scattered from Miller planes at non-n*λ spacings. However, I don't understand what these planes actually are in real life. For a diffraction grating, I can physically see the ridges on the grating, which "validates" the model for me. However, for something as complicated and non-plane-like as a protein, I completely fail to see where the planes originate.
Could someone please give me some help?
Well, I always remember that the Miller indices indicate the vector that is perpendicular to the miller plane. The vector is defined in terms of lattice vectors. So in the simplest case, a lattice is 3 orthogonal vectors of the same length. For any arbitrary miller indices, you now have a vector you can draw in 3D. Now using your vector math, you can define the plane that is perpendicular to that vector. The atoms that lie in that plane are the diffraction grating.
They are like real space crystallographic planes but in reciprocal space
But aren't the crystalographic planes arbitrarily defined? How can mathematical constructs produce physical effects?
Imagine the argument made by Miller applied not to the planes, but simply to two point particles (proteins in your case). If the phase change is zero, the reflected waves add constructively. However, since this is just for two particles, it might not amount to much. Now consider that the incoming and reflected waves define an imaginary plane running through the particles. If this plane is one of the Miller planes, then it "hits" every particle in the lattice. Which means the argument can be repeated for every particle, and ALL the reflected waves add constructively. An effect THAT large, you WILL see.
An easy way that I found to remember / find which Miller Indices belong to which plane, is to to count how many atoms laterally, and how many atoms vertically make up the plane. That is, [1 3] would be a plane that, if you start at *any* given atom in a crystal, the plane will be defined by drawing a line from that point, to the atom that is 1 row up, and 3 atoms backwards. That is. this plane would be defined by the outermost points (X) of:
X X X X
. X X X X
Have you ever held a 3-D ball-and-rod model of a simple crystal (say a cubic one like NaCl) in your hands and looked at it while rotating it? You can see the planes vividly at certain orientations.
For a two-dimensional version, draw a rectangular array of dots on a sheet of paper, and then look at it at a grazing angle from different directions.
The planes are not associated with one protein molecule but with the lattice made from many protein molecules. I suppose you are talking about a crystallized protein.
it's just convention. don't be bother too much.
10K
44K
