How to Safely Create PolyAluminum Chloride from Aluminum Chloride?
  • Thread starter Thread starter crazyd151
To safely create PolyAluminum Chloride (PAC) from Aluminum Chloride, it is essential to avoid direct reactions that may produce explosive hydrogen gas. Instead, using aluminum trihydroxide or alumina in conjunction with hydrochloric acid allows for better control over the stoichiometry of the reaction. This method minimizes risks associated with hydrogen gas release and ensures a more manageable synthesis process. Proper handling and understanding of chemical reactions are critical for success.
  • Understanding of stoichiometry in chemical reactions
  • Familiarity with hydrochloric acid properties and handling
  • Knowledge of aluminum trihydroxide and its role in synthesis
  • Basic safety protocols for handling reactive chemicals
  • Research the properties and handling of hydrochloric acid
  • Learn about the synthesis and applications of PolyAluminum Chloride
  • Study the role of aluminum trihydroxide in chemical reactions
  • Explore safety measures for working with reactive metals and acids
Chemists, chemical engineers, and hobbyists interested in synthesizing PolyAluminum Chloride safely and effectively.
crazyd151
How can I create poly aluminum chloride out of aluminum chloride? I think I need to make it into hydrochloiric acid first but to mix it safely with aluminum I need to some how do change my aluminum into something else or it may explode due to the hydrogen.
Chemistry news on Phys.org
I've seen alumina or aluminum trihydroxide used with hydrochloric acid. That gives you great control over the stoichiometry.
10K
