Plotting a potential function in MATLAB
The discussion revolves around plotting a specific potential function in MATLAB, specifically the function \(\mathcal{V}(\phi_{1}, \phi_{2}) = m^2(\phi_{1}^2 + \phi_{2}^2) + \lambda( \phi_{1}^2 + \phi_{2}^2)^2\). The context includes elements of quantum field theory (QFT) and the demonstration of spontaneous U(1) symmetry breaking. Participants share their experiences and solutions related to MATLAB plotting techniques.
  • Homework-related
  • Max seeks assistance in plotting a potential function in MATLAB, noting the different plots for \(m^2 > 0\) and \(m^2 < 0\).
  • Yuu suggests using the surf() function in MATLAB and provides a link for additional information.
  • Max shares an initial attempt at coding the function but encounters an error related to matrix operations in MATLAB.
  • Max later resolves the issue by using meshgrid to create the necessary matrices for plotting.
The discussion does not present any significant disagreements. Participants generally agree on the approach to plotting the function in MATLAB, with Max successfully resolving the initial coding issue.
Max's initial error was due to incorrect matrix operations in MATLAB, which was later corrected by using meshgrid to define the input variables properly.
maxtor101
Hi all,
I would like to be able to plot this function in MATLAB[itex]\mathcal{V} (\phi_{1}, \phi_{2}) = m^2(\phi_{1}^2 + \phi_{2}^2) + \lambda( \phi_{1}^2 + \phi_{2}^2)^2[/itex]Where [itex]\phi_{1,2} , m^2 , \lambda \in \mathbb{R}[/itex] and [itex]\lambda > 0[/itex]I am aware that the cases [itex]m^2 > 0[/itex] and [itex]m^2 < 0[/itex] yield two different plots.
I encountered this while doing some reading on QFT, this potential was used in a Lagrangian density while trying to demonstrate spontaneous U(1) symmetry breaking.
I would really like to be able to plot this in MATLAB but unfortunately I have minimal previous experience with it.
Would anybody here be able to help me please?
Thanks
Max
Hello Maxtor,
I believe the surf() function in MATLAB to be suited for your purposes.
After defining [itex]\phi_1, \phi_2, V[/itex] in MATLAB you would use it in this way:
surf(phi_1, phi_2, V). Information and examples are available here:
http://www.mathworks.de/de/help/matlab/ref/surf.html
All the best,
Yuu
Thank you for your reply!
phi1 = [-20:0.5:20];
phi2 = [-20:0.5:20];
lam = 1;
m = 1;
V = (m^2)*(phi1.^2 + phi2^2) + lam*(phi1.^2 + phi2.^2).^2 ;
surf(phi1, phi2, V)
I tried this but I get the following error:
Error using ^
Inputs must be a scalar and a square matrix.
To compute elementwise POWER, use POWER (.^) instead.
Error in p1a (line 6)
Apologies, I got it working[phi1, phi2] = meshgrid(-20:0.5:20);
lam = 1;
m = 1;
V = (m^2)*(phi1.^2 + phi2^2) + lam*(phi1.^2 + phi2.^2).^2 ;surf(phi1, phi2, V)
thanks for your help!
You are very welcome :smile:
