How Do You Solve a Time-Dependent Rate Equation?
  • Context: Graduate
  • Thread starter Thread starter CentreShifter
    Ode
The discussion centers around solving a time-dependent rate equation represented as \(\frac{dy(t)}{dt}=x-\frac{y(t)}{z}\), where \(x\) and \(z\) are constants. Participants explore methods for deriving the solution, including the use of integrating factors and the characteristics of linear differential equations. The context is primarily technical, focusing on differential equations rather than a specific application or homework task.
  • One participant expresses difficulty recalling how to solve the given differential equation and provides an assumed initial condition of \(y(0)=0\).
  • Another participant suggests using the integrating factor method, referencing external resources for further explanation.
  • A different participant proposes an alternative approach by discussing the associated homogeneous equation and deriving the general solution through characteristic equations.
  • This participant also explains how to incorporate the initial condition into the solution process, arriving at a specific form of the solution.
There is no consensus on a single method for solving the equation, as participants present different approaches and reasoning. The discussion remains unresolved regarding the preferred technique or the completeness of the solutions provided.
Participants do not explicitly state all assumptions or limitations of their methods, and some steps in the mathematical reasoning may be unclear or depend on specific interpretations of the differential equation.
CentreShifter
This is surely the simplest problem imaginable in DE, but it's been a few years and I'm having trouble recalling. The goal of my task doesn't necessitate relearning DE, so I thought I would take a shot at asking directly.
Simply, I wish to express the time-dependent rate equation [itex]\frac{dy(t)}{dt}=x-\frac{y(t)}{z}[/itex] as a function of time where [itex]x[/itex] and [itex]z[/itex] are known constants. I've been given a solution of [itex]y(t)=xz(1-e^{-t/z})[/itex] but I would very much like to remember how to get there. I do not have initial conditions, although [itex]y(0)=0[/itex] is a fair assumption for this problem.
Thank you very much in advance.
Note: this is not homework for a DE course.
Your equation is first order linear, so the standard technique is to solve it using an integrating factor. Here is a link that explains:
http://en.wikipedia.org/wiki/Integrating_factor
If you look up integrating factor on Youtube, you can see people do the technique there.
Excellent. Thank you.
Another way, though it really applies mostly to higher order equations, is to use the fact that this equation is "linear". You have dy/dt+ By= C where B= 1/a and C= x are constants.
We start by looking at the "associated homogeneous equation- just drop the "C" to get dy/dt+ By= 0. If we "try" a solution of the form [itex]y= ce^{at}[/itex], with a and c constants, [itex]dy/dx= ace^{at}[/itex] so the equation becomes [itex]ace^{at}+ Bce^{at}= 0[/itex]. Since [itex]e^{at}[/itex] is never 0 we can divide by [itex]ce^{at}[/itex] to get the "characteristic equation", [itex]a+ B= 0[/itex] so that a= -B. That is, the general solution to the associated homogeneous equation is [itex]y= ce^{-Bt}[/itex] for c any constant.
Now, we recognize that the derivative of any constant is 0 so if y(t)= D for some constant D, the entire equation becomes dy/dt+ By= 0+ BD= C and D must be C/B. That is, the associated homogeneous equation has general solution [itex]ce^{Bt}[/itex] while [itex]y(t)= C/B[/itex] satisfies the entire equation. Because this differential equation is linear, it is easy to show that adding them gives [itex]y(t)= ce^{Bt}+ C/B[/itex] is the general solution to the entire equation.
Putting B= 1/z and C= x again, that gives us [itex]y(t)= ce^{t/z}+ xz[/itex] as the general solution to the entire equation.
If we have y(0)= 0, the setting both y and t equal to 0 gives [itex]y(0)= 0= ce^{0/z}+ xz= c+ xz[/itex] so that c= -xz. Then [itex]y(t)= -xze^{t/z}+ xz= xz(1- e^{t/z})[/itex].
  • · Replies 0 ·
