Imaginary components of real integrals
The discussion revolves around the differences in the imaginary components of the incomplete gamma function and the exponential integral, particularly focusing on their definitions and behaviors along the real axis. Participants explore the implications of branch cuts and singularities in complex analysis as they relate to these functions.
  • One participant questions why the incomplete gamma function has an imaginary component while the exponential integral does not, noting a specific relationship that holds for positive real values but becomes more complex for negative values.
  • Another participant suggests that the observed differences can be explained by the conventions surrounding branch cuts, particularly that the branch cut is typically taken along the negative real axis.
  • A participant raises questions about the location of the branch cut and how it affects contour integration, particularly when multiple singularities are present in the complex plane.
  • Discussion includes a formula involving logarithms that relates the two functions, with one participant explaining that it reflects the differing paths taken around singularities in the complex plane.
  • Concerns are expressed about the variability of conventions in defining branch cuts and singularities, especially when dealing with multiple singularities.
Participants express differing views on the implications of branch cuts and singularities, indicating that there is no consensus on how these conventions apply universally across different contexts.
Limitations include the dependence on specific definitions of branch cuts and singularities, as well as the potential for varying conventions in different mathematical literature and software.
cesiumfrog
Why does the incomplete gamma function have an imaginary component, when the exponential integral does not?
[tex]\Gamma(0,z,\infty)\equiv\int^\infty_z \frac{e^{-t}}t dt[/tex]
[tex]Ei(z)\equiv-\int^\infty_{-z} \frac{e^{-t}}t dt[/tex]
Looking at how these integrals are usually defined I would have expected them to be nearly identical, [itex]\Gamma(0,z,\infty)=-Ei(-z)[/itex], for all z. Instead, while that is satisified for positive real z, the general relation is more complicated and particularly for negative real values [itex]\Gamma(0,x,\infty)=-Ei(-x)-i\pi[/itex] (e.g., according to MathWorld). Why is this?
I understand that the integrands have a singularity at the origin of the complex plane. I think I can see how integrating a contour around this will contribute ±2πi, or half that if only skipping from the positive to the negative side of the real axis. But I can't see why this would only apply when we label it the gamma function and not the exponential integral?
Plotting with Alpha/Mathematica (for real arguments) seems to confirm that the real components of [itex]\Gamma(0,x,\infty),\Gamma(0,x),E_1(x)[/itex] and Ei(x) all behave symmetrically, but that the imaginary component of Ei lacks the step-function which the others all exhibit.
Curiously, I was able to obtain the step-function in the imaginary component of Ei by subtracting a tiny imaginary component from its argument. Should I conclude that, by some quirk, Ei alone is just being defined in a completely separate manner along the real axis (perhaps, defaulting to Cauchy principal values rather than complex analysis as the method to bypass the singularity)?
More generally, for an arbitrary integrand with (multiple) singularities, is there a convention which determines which is the principal branch (e.g., why does [itex]\Gamma(0,-2)[/itex] involve negative rather than positive iπ)?
gamma(0,x,infinity)+Ei(-x)=1/2 (log(-x)-log(-1/x))-log(x)
So that explains your observation in terms of branch cuts and what not. Normally the branch cut is taken to be the negative real axis. The fact that we have introduced a negative into the argument explains the two function regard opposite sides as negative.
Thanks, lurflurf!
So.. two questions..
If the branch cut is customarily at the negative real axis, which side does that axis itself fall on? (For example, if we were to trace a contour from -1 to +1, do we pass the origin on the south side of the complex plane? And if there wasn't just one singularity on the real line but say multiple singularities arranged as the vertices of a pentagon in the complex plane, would there still be any convention or would each author place the cuts where they please?)
And secondly, how do you obtain the formula with the logs?
That is just a fancy way to write a function that is
0 when Re(x)>0
-pi i when Re(x)<0
it arises because in your two functions one path passes the singularity on the right and the other passes on the left so they differ by pi i. The same thing happens for 1/t if we pass t=0 on different sides. For a pentagon we would connect the five points with 4 lines. Which of the five to leave could very. If your want to write out a function in terms of standard function for use with tables or software great care is needed. Conventions do not always agree for different tables and software.
