Shedding some light on the dot product
The dot product of two vectors, denoted as A . B, is defined as the magnitude of vector A multiplied by the projection of vector B onto A. This operation is commutative, meaning A . B equals B . A for any vectors A and B. To find the components of a vector V in the direction of another vector W, one must use the unit vector of W, as the dot product alone does not yield this component. The magnitude of the projection of V onto W is calculated using the formula V . W / ||W||.
  • Understanding of vector operations and properties
  • Familiarity with the concept of vector projection
  • Knowledge of unit vectors and their significance
  • Basic geometry, particularly right triangles
  • Study vector projection techniques in depth
  • Learn about unit vectors and their applications in vector analysis
  • Explore geometric interpretations of dot products and projections
  • Investigate advanced vector calculus concepts, such as cross products
Students of mathematics, physics enthusiasts, and professionals in engineering or computer graphics who require a solid understanding of vector operations and their applications.
cytochrome
The dot product A . B is the magnitude of vector A times the projection of B onto A.
B . A is the magnitude of vector B times the projection of A onto B.
Correct?
A . B = B . A and this makes sense. But, say you're trying to find the components of a vector V in the direction of a vector W. Would it matter whether or not you wrote V . W or W . V?
EDIT: Also, does anyone know what it means (geometrically speaking) to find the components of a vector in the direction of another vector? I can give an example from a book if needed.
To the first question, no it wouldn't matter. The dot product is commutative so ##\vec{V} \cdot \vec{W} = \vec{W} \cdot \vec{V}## for any vectors V and W.
To the edit, imagine you have your vector lying in the plane. Now imagine it is the hypotenuse of a right triangle where one of the sides of the triangle is parallel to the x-axis and the other side is parallel to the y-axis. The component of the main vector (which remember is represented as the hypotenuse) in the x direction is the length of the side of the triangle parallel to the x-axis, and the same for the y direction.
It does not matter which way you write. But none of them will give you the component of V along the direction of W.
You need to multiply V by the unit vector along W.
So the magnitude of the projection is given by V.W/W
  • · Replies 33 ·
  • · Replies 16 ·
