Find the minimum separation between 2 pucks
The problem involves two frictionless pucks on a level surface, initially separated by 20 meters. Each puck has a specified mass and charge, with initial velocities directed towards each other. The goal is to determine the minimum separation between the two pucks as they approach each other, considering both kinetic and electric potential energy.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the application of conservation of momentum and energy to find the minimum separation. Some express uncertainty about the treatment of electric potential energy at the initial distance and whether it should be considered negligible. Others question the handling of kinetic energy, particularly regarding the sign of velocities and the contributions of potential energy at both initial and final separations.
There are multiple interpretations of the problem, with participants providing their calculations and questioning each other's reasoning. Some have offered guidance on re-evaluating the initial conditions and the contributions of potential energy, while others have acknowledged errors in their calculations and are seeking confirmation on their revised approaches.
Participants note that the initial separation of 20 meters may lead to assumptions about the negligible electric potential energy, which is under discussion. There is also mention of significant figures in the final results, indicating attention to precision in calculations.
Helios12
Two frictionless pucks are placed on a level surface with an initial distance of 20m. Puck 1 has a mass of 0.8 kg and a charge of + 3x10^-4 C while puck 2 has a mass of 0.4 kg and a charge of +3 x10^-4 C. The initial velocity of puck 1 is 12 m/s [E] and the initial velocity of puck 2 is 8 m/s [W]. Find the minimum separation of the two pucks (the minimum distance between the two pucks).
This is my attempt at a solution
I first used the law of conservation of momentum to find the velocity of each mass at minimum separtion. The 2 masses have the same velocity at this point.
Note: [east] is positive
Pt=Pt'
m1v1+m2(-v2)=(m1+m2)v'
isolating for v'
v'=(0.80)(12)+(0.40)(-8)/0.80+0.40
v'=5.33 m/s [east]
Next i used the law of conservation of energy:
Ek=kinetic energy
Ee=electric potential energy
Ek1+Ek2=Ee+Ek'
1/2m1v1^2 + 1/2m2(-v2^2) = kq^2/r + 1/2(m1+m2)(v')^2
inserting each value
1/2(0.80)(12)^2 + 1/2(0.40)(-8)^2 = (9.0X10^9)(+3.0X10^-4)^2/r + 1/2(0.80+0.40)(5.33)^2
isolating for r (the distance) I get:
r=15.2 m
so the minimum distance between the 2 pucks is 15.2 m
Is this correct? I am not feeling too confident with my answer of 15.2 m it just seems too big a separation. If i made a mistake or forgot to include something or included something i shouldn't have. please let me know. Also I am not sure if i am correct in assuming that there is no electric potential energy when the pucks are 20 m apart. It seems that they are too far apart to have any electric potential energy between them. Can someone confirm this with me also?
It took me some time to write this up so can someone please look over my answer and the questions that i have. It would be most appreciated!
bump? i have the same problem and got the same answer - was wondering if it is correct
Looks dubious to me. I just glanced at the workings and it doesn't look like the electrical PE is being handled properly --- there should be contributions at both initial and final separations. And for the initial KE, why is the square of the velocity of the second puck made negative?
Perhaps you should make your own, fresh attempt.
Its negative because its traveling in the opposite direction. I've attached a picture of the situation.
Here's my work (let's ignore, for now, what's done):
Let East [E] = (+)
di=20m
m1=0.8kg
q1=+3*10^-4 C
Vi1 = 12m/s
m2=0.4kg
q2=+3*10^4 C
vi2= -8m/s
rmin=?
vf' = vf1 = vf2
ptotal=p'total
m1v1+m2v2=(m1+m2)v'
9.6-3.2=1.2v'
6.4/1.2 = v'
v' = 5.333 m/s [E]
I didn't include initial electrical potential energy in this next part because its negligible at that distance (20m).
EK1+EK2 = EE+E'K
0.5(0.8)(12)^2 + (0.5)(0.4)(-8)^2 = (k(3*10^-4)^2)/r +0.5(0.8)(0.4)(5.33)^2
57.6+12.8=k(9*10^-8)/r + 17.04534
53.46566=k(9*10^-8)/r
53.46566r=k(9*10^-8)
r = 15.18142933
bon?
Kinetic energy has no direction, it's always a positive scalar value. KE from all particles sum to a total.
Let East [E] = (+)
di=20m
m1=0.8kg
q1=+3*10^-4 C
Vi1 = 12m/s
m2=0.4kg
q2=+3*10^4 C
vi2= -8m/s
rmin=?
vf' = vf1 = vf2
ptotal=p'total
m1v1+m2v2=(m1+m2)v'
9.6-3.2=1.2v'
6.4/1.2 = v'
v' = 5.333 m/s [E]
You'd better confirm that. Especially since your 'final' distance of around 15m isn't significantly different. What's the PE for the initial separation?
EK1+EK2 = EE+E'K
r = 15.18142933
bon?
Check the potential energy contribution and redo.
EE+EK1+EK2 = E'E+E'K
(k(3*10^-4)^2 )/20 + 0.5(0.8)(12)^2 + (0.5)(0.4)(-8)^2 = (k(3*10^-4)^2)/r +0.5(0.8)(0.4)(5.33)^2
40.5+57.6-1.6=810/r' +17.0645334
r'=10.19695653m
I was wrong about the initial electrical potential energy. I thought that at that range, its magnitude would be minuscule.
OH WELL.
How's that look?
r'=10.19695653m
OH WELL.
How's that look?
Still not quite right. Check your KE for m2. The magnitude of the value looks incorrect, and KE is never negative!
Damnit. When I wrote the calculation down on paper, I forgot to include the square on the (-8).
40.5+57.6+12.8-17.0645334=810/r'
93.8354666r'=810
r'=8.632130572m
That looks much better :smile:
Be sure to round your final results to the appropriate number of significant figures.
thanks!
93.8354666r'=810
r'=8.632130572m
quicksilver123
I ended up with the same steps and answer, wondering if it ended up being correct in the end?
