Partition function related to number of microstates
The partition function, defined as Z = ∑ e^{-βε_i}, is directly related to the number of microstates Ω through the equation Ω = Ze^{βU}. This relationship arises from the application of the Helmholtz free energy F = U - TS and the Shannon entropy formula S = -k∑P_i log P_i. The discussion clarifies that Boltzmann's entropy formula S = k_B log Ω is applicable only in a microcanonical ensemble, while the partition function corresponds to a canonical ensemble where microstates are not equally likely.
  • Understanding of statistical mechanics concepts, particularly partition functions.
  • Familiarity with the Helmholtz free energy and its relation to entropy.
  • Knowledge of canonical and microcanonical ensembles in thermodynamics.
  • Proficiency in mathematical expressions involving summations and exponentials.
  • Study the derivation and applications of the Helmholtz free energy in statistical mechanics.
  • Learn about the differences between canonical and microcanonical ensembles.
  • Explore the implications of the partition function in quantum statistical mechanics.
  • Investigate the role of entropy in thermodynamic systems and its mathematical formulations.
Researchers, physicists, and students in the fields of statistical mechanics and thermodynamics, particularly those interested in the relationship between partition functions and microstates.
Troy124
Hi,
I have a question about the partition function.
It is defined as ## Z = \sum_{i} e^{-\beta \epsilon_{i}} ## where ##\epsilon_i## denotes the amount of energy transferred from the large system to the small system. By using the formula for the Shannon-entropy ##S = - k \sum_i P_i \log P_i## (with ##k## a random constant or ##k_B## in this case), I end up with the following: $$ S = - k \sum_i P_i \log P_i = (k \sum_i P_i \beta \epsilon_i) + (k \sum_i P_i \log Z) = \frac{U}{T} + k \log Z $$
This simplifies to ##Z = e^{-\beta F}## by using the Helmholtz free energy defined as ##F = U - T S##. But Boltzmann's formula for entropy states ##S = k \log \Omega##, where ##\Omega## denotes the number of possible microstate for a given macrostate. So we will get $$ \Omega = e^{S/k} = e^{\beta (U - F)} = Z e^{\beta U} $$
So the partition function is related to the number of microstates, but multiplied by a factor ##e^{\beta U}##. And this bring me to my question: why is it multiplied by that factor? Maybe the answer is quite simple, but I can't seem to think of anything.
Science news on Phys.org
Troy124 said:
Hi,
Boltzmann's formula ##S = k_B \ln \Omega## is applicable only to the case of a microcanonical ensemble - a system in which every microstate is equally likely. Note that setting ##P_i = 1/\Omega## in ##S = -k_B \sum_{i=1}^\Omega P_i \ln P_i## gives Boltzmann's formula.
The partition function ##Z = \sum_i \exp(-\beta \epsilon_i)## corresponds to a canonical ensemble. The microstates in a canonical ensemble are not equally likely, so Boltzmann's formula ##S = k_B \ln \Omega## does not apply. (However, the more general formula, ##S = -k_B \sum_{i=1}^\Omega P_i \ln P_i##, does still apply).
You can thus not equate ##\Omega## to ##Ze^{\beta U}##, as the two formulas you used for entropy are not simultaneously true.
Hi,
Thanks for your reply. I finally figured out that I mixed up the entropy of the environment with the entropy of the system, because my idea was that the total system, so environment + system, could be described by the microcanonical ensemble and I could use Boltzmann's formula, but then you will end up with something different:
The system including its environment can be described as a microcanonical ensemble. The number of possible configurations for this ensemble are ##\Omega_{total} = \sum_i w_i## where ##w_i## denotes the number of possible configurations given an ##\epsilon_i##.
We know $$w_i = \Omega (E-\epsilon_i) \Omega (\epsilon_i)$$ (with ##\Omega (\epsilon_i) = 1##, ##\Omega (E-\epsilon_i)## the number of microstates of the system when its energy equals ##E-\epsilon_i## and ##\Omega (E)## the number of microstates of the environment, when it is not thermally connected to another system) and thus $$ \Omega_{total} = e^{S_{total}/k} = e^{S/k} e^{S_{env}/k} = e^{\beta (U - F)} \Omega_{env} = \sum_i \Omega (E - \epsilon_i) = \Omega (E) \sum_i e^{-\beta \epsilon_i} = \Omega (E) e^{-\beta F}$$
This simplifies to $$ \Omega_{env} = \Omega (E) e^{-\beta U}$$
Do you know if this is correct, because I have never seen this result before. It does seem okay to me though.
  • · Replies 17 ·
  • · Replies 22 ·
