robphy said:
As was mentioned, one can introduce an origin by introducing a coordinate system.
That is sufficient but it is not necessary. I can introduce an origin without introducing any coordinate system whatsoever.
Ratzinger said:
But what does that imply for my initial question. What is the nature of position vectors? Is the term position vector inappropriate since position is not a vector quantity but a coordinate–dependent concept?
The term "position vector" is very appropriate because it is
not a coordinate dependent concept. I fail to understand why you keep insisting that it is!? If you keep thinking that r = (x,y,z) then you're in big trouble and you've failed to understand this vector. (x,y,z) is
only a
representation of the position vector as expressed in Cartesian coordinate systems.
Many physicists actually use the position vector as the prototype of a vector when they choose to define "vector" in terms of transformation properties. So in that case the position vector is a vector
by definition. In fact if you have
Classical Electrodynamics - Second Edition by J.D. Jackson then turn to section 6.11 which starts on page 245. It will explain this. Basically a "vector" is an object whose Cartesian components transform in the same way as the Cartesian components of r = <x, y, z>.
So that you understand why I'd like to see you stop using <x, y, z> then express the position vector in spherical coordinates. You'll see that its simly
r = r
er =
r(r, [itex]\theta[/itex], [itex]\phi[/itex]).
er is a unit vector which points in the direction of the position vector and is a function of [itex]\theta[/itex] and [itex]\phi[/itex].
Have you studied vector analysis in other coordinate systems?
When you study special relativity then you'll see the 4-position which can be expressed in Lorentz coordinates as
X = (ct, x, y, z). This is the prototype for Lorentz 4-vectors.
Pete
