Basic intersection/union probabilities.
  • Thread starter Thread starter caffeine
    Probabilities
caffeine
Probability self-study question (please see attached png for diagram).
In the following diagram, A, C, and F have a 50% chance for success. B, D, and E have a 70% chance for success. What is the overall probability for success?
Here's what I've done:
<br /> A \cap \left[ C \cup \left( E \cap \left[ B \cup D \right] \right) \right] \cap F<br />
plugging numbers,
<br /> .5 \times \left[ .5 + \left( .7 \times \left[ .7 + .7 \right] \right) \right] \times .5<br />
My calculator says .37. The book says .20. Where did I go wrong?
ACF = 0.5 0.5 0.5 = 0.125
ABEF = 0.5 0.7 0.7 0.5 = 0.25 0.49 = 0.1225
ADEF = ABEF = 0.1225
Sum = 0.37
Sum = 0.37
So you're implicitly saying the book's answer is wrong?
Do a quick sanity check on your work. Look at the diagram. The probability of success is P(A)*P(success on path from A to F)*P(F). Since P(success on path from A to F) <= 1, P(success) <= P(A)*P(F) = 0.25. Your answer (0.37) cannot be correct.
What you have done wrong is to not take into account (for example) B and D both succeeding.
For the book to be correct you need P(success between A and F) = 0.8.
It is, more-or-less. The exact value is 0.8185, making the end-to-end probability of success 0.204625. The book or the original poster must rounded that to two significant digits.
I gave a hint on how to get to the correct probability: make sure not to exaggerate success on parallel paths. To see why this must be the case, consider the first half of the upper path between A and F: the parallel branch B and/or D. It is incorrect to compute the probability of B and/or D being successful just by adding the probabilities. (Sanity check again: these sum to 1.4, which is not a valid probability). In set theoretic terms, the correct calculation is
<br /> \begin{align*}<br /> P(B \cup D) &amp;= P(B) + P(D) - P(B \cap D) \\<br /> &amp;= P(B) + P(D) - P(B)*P(D) \\<br /> &amp;= 0.91<br /> \end{align*}<br />
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
