Engine sounds again this time its all about diesels
  • Thread starter Thread starter enginelover
    Engine Time
The discussion revolves around the sounds produced by diesel engines, particularly focusing on the "pitter patter" noise heard when they are cold. Participants explore the causes of this noise, comparing it to sounds from air engines and discussing the differences in combustion mechanisms between diesel and gasoline engines.
  • Some participants question whether the cold noise in diesel engines is due to combustion noise or mechanical noise from the valve train.
  • One participant suggests that the noise is related to the injector solenoids, while another argues it is primarily due to combustion.
  • There is mention of newer common rail direct injection engines being particularly noticeable in terms of sound.
  • Some participants discuss the impact of pilot injections on reducing noise in newer diesel engines.
  • One participant notes that diesel engines have always produced a rattle regardless of the fuel injection scheme used.
  • There is a discussion about the differences in sound between turbo-diesels and gasoline engines, with some noting that turbo-diesels can sound like air blowers or jet engines at high RPMs.
  • Participants mention the design and thermal expansion of pistons in diesel engines as contributing factors to the noise, with wider tolerances in piston rings leading to louder clatter.
  • One participant requests sources for claims about piston ring tolerances, and another provides links to relevant papers.
Participants express differing views on the primary source of the noise in diesel engines, with no consensus reached on whether it is due to combustion, mechanical noise, or injector solenoids. The discussion remains unresolved with multiple competing explanations presented.
Some claims about the mechanics of diesel engine noise are based on personal experience and observations, and there are references to specific engine designs and technologies that may not be universally applicable.
enginelover
engine sounds again :) this time its all about diesels
hmm hi
i just discovered this forum :)
and i just loved it
have been looking around for something like this for some time :)
i just went through the engine sound thread a while back
i have two questions.
1)
why do diesels make the pitter patter noise(for the lack of a better word:redface:) when they are cold(is this combustion noise or the noise of a pressure wave from the exhaust valve)?
and
has anyone heard an air engine ?
whats the difference in sound?
i am not too sure about how they work but i do know they run on compressed air and hence no combustion takes place in their cylinders.
so was wondering if this makes any sense to you guys :)
If you're referring to that raucous 'clacking', I've always been under the impression that it's mechanical noise from the valve train. It comes from the engine compartment, not the exhaust. I've never actually investigated it, though.
hmm not the clacking
have you heard any new generation common rail direct injection engines?
its particularly noticeable in those
I'm sure that I have—you can't turn around in these parts without bumping your ass on a diesel pick-up—but I've never paid any attention. This is the wrong time of year to try hearing one that's cold, but I'll keep it in mind for winter.
I can tell you it is definitely NOT the valve train. I was working on a Ford Powerstroke 7.3L diesel that had one side (V8) that was not firing. Turned out that the wires that carry current to the injectors and the glow plugs plug into a harness which is part of the valve cover gasket. It is a way to get the the signals that fire each injector and carry current to the glow plugs under the valve cover. The connector part of the valve cover gasket had melted and was not firing the injectors on that side of the engine. There was NO diesel rattle coming from that side of the engine. The rattle appears to come when the fuel is injected. Diesel engines have rattled ever since I can remember no matter what scheme they use for fuel delivery. Some of the newer diesel engines are quieter than previously. However, the Powerstroke IS a common rail design and is just as noisy as any diesel I've been around. Also, aren't ALL diesel engines considered direct injection?
crdi and di
the difference i guess in the sound is more due to the pilot injections as they call it
a couple of smaller injections of diesel followed by a big one so there is less noise
so its particularly noticeable there
and am sure it is not valve noise cause i have hard diesels with their tappet clearances screwed so i know what that is
That's interesting, Average. Thanks for (partially) straightening that out. I'm still confused, though. Is it the injector solenoids themselves making the racket, or what?
As near as I am able to tell, it is the actual combustion that gives a diesel its familiar rattle. As I said in a previous post, diesel engines have ALWAYS had a rattle no matter what fuel injection scheme they use. It has little to do with the solenoid at least on Ford Powerstroke. (Which is actually made by International)
hmm yeah i agree with you :)
Okay, that's what caused the confusion. I forgot that diesels combust immediately upon injection. :redface:
Danger,
Did you notice I didn't bust your chops for not using my full username? :smile:
Yeah. Sorry, man... it's just laziness on my part. Maybe I'll just stash your full name in the clipboard and paste it in when needed. :biggrin:
Averagesupernova said:
Danger,
lolzzzzzzz
Diesels 'rattle' more because of the different combustion mechanism. When the fuel is injected, there's a higher initial heat release than with spark ignition engines. Common rail engines are even noisier because of the higher injection pressures allowing an even higher initial heat release spike.
As Brewnog said it. However for turbo-diesels, and at high RPM, I barely notice that sound, they sound more like large air blowers or even like jet engines. They are unlike gasoline engines even high RPM, the sound pulses is neatly distinguished.
Indeed, but if you even think about describing any real engine sounds like turbos, pumps, induction systems, injectors, valvetrains or fans, the OP is likely to tell you that you haven't got a clue...
my new to me older MB 300sd is much louder at idle then at speed
diesels knock as the fuel goes bang
gas motors burn more slowly and only knock if something is very wrong
some call the diesel sounds pennies in a can at lower speeds and idle
newer diesel cars use muliti injection pulses [computer controled]
to try to reduce noise and gain MPG too
but at a cost of complex controls
The diesel "clatter" comes from the design and principles of diesel combustion. Diesel fuel is not ignited with a spark plug as gasoline is, it combusts on its own as it is injected into the cylinder. Also diesel fuel required extremely high temperatures to ignite. The combination of these two requirements makes it necessary to keep the combustion chambers very hot while the engine is running.
Now automotive pistons are made from aluminum, and newer ones iron/maganese. When you heat up a metal it expands proportional to its coefficient of thermal expansion. Because diesel engines run hotter than gas, their pistons experience greater expansion. To seal the gap between the pistons side face and the cylinder walls, piston rings are used. In order to compensate for the greater expansion of pistons the piston rings in a diesel engine are run at a wider tolerance than a gas engine. This larger gap between the piston and the wall cause the loud clatter.
Piston ring clearance in diesel engines have been getting closer in recent years (Compare an E320CDI to a 300SD), and thereby quieter.
Got a source for this please?
i think what srode said makes sense. atleast it is a possible explanation. but i ll first check out the pistons from a diesel and a gas engine.
24K
  • · Replies 22 ·
  • · Replies 39 ·
