Ball being thrown against a wall
  • Thread starter Thread starter turnip
    Ball Wall
The problem involves a 120 kg ball striking a wall perpendicularly at an initial speed of 18 m/s and rebounding at 12 m/s, with a displacement of 0.27 cm closer to the wall after contact. The objective is to determine the time of contact and the average force exerted on the wall, assuming uniform deceleration.
  • Participants discuss the application of various equations of motion and the work-energy theorem. There are questions about how to incorporate the given time into calculations and whether to use average velocity in determining displacement.
Some participants have suggested breaking the problem into two parts to analyze the deceleration and acceleration phases separately. There is recognition of the complexity in calculating the average force due to differing accelerations during the ball's contact with the wall. Clarifications regarding the use of specific formulas and the meaning of average velocity have been provided.
Participants note that the actual displacement of the ball is not straightforward, as it involves understanding the initial and final positions relative to the wall. There is also mention of the assumption of uniform deceleration, which may not hold true for both phases of the ball's motion.
turnip
a 120kg ball moving at 18m/s strikes a wall perpendicularly and rebounds straight back at 12m/s. after the initial contact, the centre of the ball moves 0.27cm closer to the wall. Assuming uniform deceleration, show that the time of the contact is 0.00075s. How large an average forced does the ball exert on the wall?
i figure that:
m=.12
u= 18
v=12
s1 - s2 = 0.0027
s1 = s2 + 0.0027
f= delta p/t
= mv-mu/t
s=ut+1/2at(squared)
p=mv
what threw me off is the the time, i can get the average force no problem after i have the time.
my question is do i put the time (0.00075) into the equation s=ut+1/2at(squared), because i have done that which worked out wrong.
or
do i rearrange and substitute some other formulas? if i don't have any formulas needed please tell me!
Try work energy theorem here.
Fd = change in Ek
Trying one way I get this ridiculously large # for force: 7 x 10^6 N
I assumed that it took 0.27 cm to stop the ball from speed of 18 m/s
thank you for trying, but the way i read it, the actual displacement is unknown
you see the ball hits the wall starting at displacement = x
after it rebounds off the wall it is .27 cm closer from its original starting point of x
therefore it is: displacement after rebound = x - .27 cm
anymore ideas anyone?
To get the time, you need to divide the problem into two parts... first find the time it takes to be brought to 0m/s from 18m/s... then find the time it takes to go from 0m/s up to 12m/s.
I get the given time of 0.00075s.
For the second part, Faverage*time = change in momentum. (oops nevermind, I just saw that you got this part).
The trick to this problem is that the accelerations for the two parts are not the same... ie: the deceleration from 18m/s to 0m/s is different from the acceleration from 0m/s to 12m/s.
okay i get that, but could you please explain how you algebraically got the acceleration because i can only think of f=ma and a = v-u/t but both have two variables!
if you could please explain the acceleration i will be right from there thanks :)
well, you don't need acceleration... you need time:
so for the first part:
d = (v1 + v2)/2 * t
0.0027 = (18 + 0)/2 * t
solve for t
get t = 0.0003s
do the same thing for the second part... v1 = 0 v2 = 12.
if you want to get acceleration (you don't need to get it)
use v2^2 = v1^2 + 2ad.
right. just one more thing i don't get:
d = (v1 + v2)/2 * t
i understand the formula, but what's with the /2 part of it?
is that to get the average velocity?
d = (v1 + v2)/2 * t
yes. distance = average velocity * time. [tex]d = \frac{(v1+v2)}{2}*t[/tex]
thanks that was very clearly explained :)
