| Thread Closed |
Why aren't heavier metals like uranium and mercury found in abundance in the core? |
Share Thread | Thread Tools |
| Aug12-08, 10:14 PM | #1 |
I'm curious as to why there aren't heavier metals in the earth's core than iron and nickel. Why those two? Anyone have any insight?
| Aug13-08, 04:38 AM | #2 |
![]() There are … see http://en.wikipedia.org/wiki/Core_(earth_science): |
| Aug13-08, 05:49 AM | #3 |
Nickel and iron are more abundant in the universe (or at any rate in the Solar system) than heavier substances, and might therefore dominate the core even if most of these other substances would have accumulated there.
On the other hand, some substances, like iodine, or mercury, might be mostly locked into molecules with less density than iron, or dissolved into subtances with less density than iron, like aluminium or water, and might therefore not be more abundant in the core than in the mantle or crust. |
| Aug13-08, 05:51 AM | #4 |
Welcome, Danie
What happens in the core is all pure hypothetical, since we have only some very indirect observations. The wiki ref of tiny-tim is certainly true qualitatively but there is no way of quantifying the concentration of heavy elements in the core as well as their contribution to the terrestrial generated heat. There are more hypotheses going around, none of which can be selected as being the right one. The iron - nickle abundance is no doubt related to the total abundance of those elements in the solar system, whereas the heavy elements are much more rare. Another element could be, the order in which compounds became fluid or not, during the -hypothetical- iron catastrophe But in the end it's all a sophisticated guess. |
| Aug18-08, 04:38 PM | #5 |
![]() Actually, I'd like to ask a question related to this one.... and that is why is gold associated with volcanic activity? Does it get separated out by extreme heat or is it of greater abundance in the liquid magma surfacing during a volcanic eruption? Many thanks! |
| Aug18-08, 04:58 PM | #6 |
Recognitions:
| Aug18-08, 05:39 PM | #7 |
| Aug21-08, 05:47 AM | #8 |
If the core of Jupiter is made of diamond, that would mean that carbon is dominating Jupiter's core. One would have to conclude that elements heavier than carbon (such as iron and nickel) are relatively rare on Jupiter. In that case iron and nickel cannot be all that common in the Solar System, and one would have to wonder why they are common on Earth.
That is quite different from the case for hydrogen. Hydrogen is the most common element in the universe, but Earth cannot keep hold of it (except in compounds with heavier elements, such as oxygen), because it is light enough to escape from Earth's gravity well. Jupiter is more massive, and was therefore able to retain more hydrogen. Carbon, however, would not escape from Earth, at least not over the present age of the Solar System. If a large part of Jupiter is made of carbon, that would be strange. |
| Aug21-08, 11:15 AM | #9 |
| Aug21-08, 11:24 AM | #10 |
Recognitions:
| Aug21-08, 02:12 PM | #11 |
There is definitely more realistic speculation of metallic hydrogen in jupiter's core, but I don't think that's been verified either. |
| Aug21-08, 10:28 PM | #12 |
| Aug21-08, 10:40 PM | #13 |
I'm sorry, I mentioned the diamond centre of Jupiter as a joke... sort of sarcastic kind of thing.
| Aug21-08, 10:47 PM | #14 |
Recognitions:
Diamond isn't the most stable form of Carbon, diamonds (slowly) decay into graphite at room temperature - I don't know about at the pressure in the centre of a planet |
| Aug21-08, 11:33 PM | #15 |
| Aug22-08, 04:57 AM | #16 |
| Aug22-08, 07:34 PM | #17 |
Could one assume that if there is carbon in or near the core, it is probably in diamond form?
| Thread Closed |
| Thread Tools | |
Similar Threads for: Why aren't heavier metals like uranium and mercury found in abundance in the core?
| Thread | Forum | Replies | ||
| abundance of isotopes | Chemistry | 2 | ||
| CPU differences: quad core, dual core, etc. for CFD | Mechanical Engineering | 3 | ||
| Percent Abundance | Introductory Physics Homework | 1 | ||
| the problem with abundance.... (link) | Computing & Technology | 5 | ||
| Relative Abundance? | Introductory Physics Homework | 2 | ||
