Potential difference to stop an electron question
The problem involves an electron with an initial speed of 4.70×105 m/s being brought to rest by an electric field. The goal is to determine the potential difference required to stop the electron.
  • Participants discuss the relationship between electric fields, forces, and potential difference in stopping the electron. There are questions about the completeness of the problem statement and the relevance of distance or time in determining the potential difference.
Participants are exploring various interpretations of the problem, including the need for additional information such as distance or time to stop the electron. Some guidance has been offered regarding the relationship between kinetic energy, work, and potential difference, but there is no explicit consensus on the approach to take.
There is uncertainty regarding whether the problem is fully stated, as participants note that any electric field could theoretically stop the electron eventually. The discussion also touches on the implications of the electron's charge and the nature of the electric field required.
cwesto
An electron with an initial speed of 4.70×105m/s is brought to rest by an electric field.
What was the potential difference that stopped the electron?
Unknown:
potential difference or [tex]\Delta[/tex]V
Known:
vo=initial speed
m=mass of electron
q=charge of electron
[tex]\Delta[/tex]Vq+[tex]\frac{1}{2}[/tex]*mv2=[tex]\Delta[/tex]Vq
I figure basically plug and chug but my equation doesn't seem right. I sure it's not. Basically I don't know where to go from here.
Welcome to PF!
Two questions. Are you sure this is the whole question? With these values, we could use almost any kind of electric field to stop the electron. Where'd you get that equation?
Well, I'll take a stab at helping out...
You need to stop a moving electron, right? Does that mean you will have an acceleration (or deceleration, same thing)?
If you have an acceleration, there's a force. And the force in this case is related to the electric field, right?
So you need an electric field such that it creates a force capable of stopping your electron.
If you can find the electric field, you *should* be able to relate the electric field to the potential energy, relate that to the electric potential, and then find a potential difference...
But then, I haven't worked a problem like this in awhile and I may not be solving it with the tools that you already have... Have you done line integrals and all that stuff yet?
Sonolum, if the given problem is the whole problem, even the smallest force is enough to stop the electron eventually. Why go for the trouble of using line integrals?
I don't really see them so much as trouble, myself... I was mostly trying to get a feel for the level of this problem and help out.
I also told the electron will move to a region of lower potential. I got the equation from a previous question that is simliar posted on PF last year. That's all I have. The link to the previous question is below.
(https://www.physicsforums.com/showthread.php?t=234536)
Ah, see, in that problem we know how much distance we have to stop the electron. Here, we don't know that - do we have to stop the electron in a certain time? In a certain amount of distance?
Kruum's 100% right, I didn't realize it at first, but yeah, any electric field that opposes the electron's motion will *eventually* stop it. It kinda depends on where/when you want to stop it to get anything specific.
I think you need to understand that the kinetic energy is to be absorbed by work from some source. In this case measuring the work can best be done by observing that changing the voltage of a charge can be determined by:
W = q*ΔV and that would equal ½mv² in order to stop it.
Hence won't the needed ΔV = ½mv²/q ?
So in other words I need to know something else?
Like what?
I dunno, Pion's method seems a heckuva lot more eloquent and to the point... But I pretty sure it's (Delta)V = - W/q...
Oh crap! I should read the question a bit more carefully! :blushing: Sorry for the confusion cwesto!
LowlyPion said:
Like what?
The distance in which they want the electron to stop.
Happily q is (-) electron which makes the ΔV (-).
cwesto said:
The distance in which they want to electron to stop.
No distance required.
If the E-Field is 1000 V/m or 10 V/m the distance would change of course but not the ΔV required.
Wouldn't "ΔV = ½mv²/q" give me ΔV while the speed is 4.70×105m/s?
I want to know the ΔV when the speed is 0.
I'll ask my professor then post. I have class now. Thanks though.
Ah, but see, that's why there was mention of changing the kinetic energy into work, right? The energy had to go*somewhere*, and the energies should be equivalent before and after, right?
Oh yeah!
ΔV = ½mv²/q
Your right. Thanks.
Awesome! Physics Rules!
  • · Replies 34 ·
  • · Replies 30 ·
