What Resources Help Beginners Learn Gambit/Fluent CFD Software?
  • Thread starter Thread starter anthro
    Cfd
The discussion revolves around resources and guidance for beginners learning the Gambit and Fluent software, which are used for computational fluid dynamics (CFD). Participants seek recommendations for tutorials, books, and troubleshooting advice related to these tools, as well as clarification on their functionalities and applications.
  • Homework-related
  • Some participants inquire about resources such as websites and books to learn Gambit and Fluent, expressing their status as beginners.
  • One participant explains that Gambit is primarily a mesh generator while Fluent serves as a flow solver, emphasizing the sequential use of both software.
  • A suggestion is made that the built-in tutorials of Fluent and Gambit are valuable resources for beginners.
  • Concerns are raised about the limited time available for learning these complex software tools, with one participant noting the importance of having experienced guidance.
  • Several participants ask specific technical questions, such as how to export meshes from Gambit to Fluent, how to generate specific geometries, and how to address errors encountered during the process.
  • There are discussions about alternative software options for CFD, including ANSYS CFX and MATLAB, with varying levels of certainty expressed regarding their capabilities.
  • One participant mentions the need for foundational knowledge in CFD before diving into the software, recommending a textbook for better understanding.
  • Technical challenges related to coordinate systems in Gambit and mesh generation are also raised, with participants seeking advice on these issues.
Participants express a range of opinions on the best resources and approaches for learning Gambit and Fluent, with no clear consensus on specific recommendations or solutions to technical problems. Multiple competing views on the use of alternative software and methods are present.
Some technical questions remain unresolved, such as the specifics of mesh export errors and the generation of geometries in cylindrical coordinates. Participants also express uncertainty regarding the relationship between Gambit and Fluent in the context of CFD.
This discussion may be useful for beginners in CFD looking for resources to learn Gambit and Fluent, as well as those facing technical challenges with these software tools.
anthro
Hi, can anyone recommend me any site/books that could help me to learn the Gambit/Fluent software. Btw, what is the difference between these 2 softwares??
I am a beginner, totally alien to these softwares and I have about a month to learn it.
Thanks a lot.
softwares??
Gambit is a mesh generator, and Fluent a flow solver. You first use Gambit to make a discretization of flow domain, and then Fluent to solve the flow in it.
Never used these personally, but a colleague of mine once pointed me to this link as nice set of beginner's tutorials:
http://instruct1.cit.cornell.edu/courses/fluent/
A month is not a good time. There is a strong junk-in-junk-out tendency with CFD software: if you have no experience, you don't know whether what you are giving it makes any sense, and you don't know whether the results it gives you back make any sense.
It is good if there is someone experienced around to check your inputs and outputs while you are working out the problems, for months probably.
Chusslove Illich (Часлав Илић)
Doubtless the best sources are the in built tutorials of Fluent and Gambit that come with the cd's. They have a collection of great exercises using all the important features.
thanks a lot. Really appreciate your help!
How can I get the vertices of the NACA0015 profile for designing it in Gambit? Can u tell me the detailed way of doing so??
is it possible do the flow problem using ansys instead of fluent...
hi..u can use many other softwares...u cn use ANSYS CFX...
not sure about this but MATLAB can also be used i guess
Hello,
Is there any CFD for Catia V5 R18??
doubt
is it possible to use proe to send design to fluent if so how
Dear
I'd like to know how to do energy imbalance test in fluent
Thanks
Try google.
hello, am israa working in my final project using cfd fluent ;
but am having trouble in exporting the mesh from gambit to fluent 6 because as the error written in gambit " face (no) has ahigher order element & cannot be exported to fluent5"
if anyone knows how can solve this problem please reply....
I think (but I'm not sure) that you export 2d for 3d elements. That's my first guess
If you draw your geometry in PRO-E you need to import it into GAMBIT great your mesh and then you can use it in PRO-E.
In order to do that you need to:
1. Draw your geometry
2. Save it in your working directory
3. Then File -> Save a copy -> select the drop down menu and select .igs extension and save it.
4. Open GAMBIT then File -> Import -> select the required document.
hi..
to all freinds
i want to know about PRO/ENGINEERS ,i want to draw geometry of ESP in pro/E,
is it possible to draw in pro/e,i am doing project on ESP performance,
please help me
thankss
hi,
i am doing a simulation of 3D problem.i want to draw it cylindrical coordinate sysyem(r,z, o).but gambit shows X , Y , Z Coordinate . how to do in cylindrical co ordinate , will it show r, z and o axis ?
i opened the Tools command button then i changed the co ordinated system to cylindrical and I acctivé it . but it still at cartesien coordinate
please reply
hi,
please reply
Hi,
I want to generate a mesh file by myself in a format the same as GAMBIT out put file, to use in Fluent. I face to this problem that I don't know how Gambit count the Elements, I mean how Gambit count an Element as Element no. 1 or 2 or 50. I generate meshes but I don't know which Element is number 1 or 2 or...
and if there is a manual that explain different lines of Gambit output file that shows the points coordination and Points of an elements.
I would be thankful for your nice help
Gambit software is use for CFD flow analysis.It is application software software use for CFD.But i do not know so much about fluent software.Can anyone provide more information about this.How is these software related to CFD trading?
____________________
For more information Visit:http://www.igmarkets.com.au/"
Hi,
I am a beginner and still learning to use gambit and fluent for my project. I am trying to model dispersion of gas from a pipeline. So I created a horizontal cylinder with a vertical cylinder on top of it to represent a hole. Then I subtract that vertical cylinder from the 1st cylinder. Then I try to do the meshing. I thought that it could work just like that. But it seems like I miss some steps but I don't know what is it. Please help me. Your kind help is greatly appreciated. Thank you in advance.
Hi
Just one suggestion from my side. Before you start exploring Fluent and Gambit try to clear your basics with Text books of CFD. One of the god book which I noramlly use it "Computational Fluid Dynamics" By John D Anderson JR. This book really helps you at every stage while you are working on Fluent.
hi,
thank you vikram.karwal. I've found the book.
Please, Can anybody tell me how can I draw A 3D wind turbine blade on gambit?
hi,
i am doing project on pre-mixed combustion chambers and i need help to find some useful literature survey on 'multiple co-axial nozzles'.
if possible any were do i get more elaborate explanation of non-circular exit nozzle analysis...
I want to know if it is possible to simulate a two-dimensional infinite cavity type rayleigh-benard in gambit
  • Poll Poll
47K
  • · Replies 24 ·
  • · Replies 45 ·
