Calculate Transmission & Concentration Using Beer-Lambert Law
  • Context: Graduate
  • Thread starter Thread starter nordmoon
    Law
The discussion focuses on calculating transmission and concentration using the Beer-Lambert Law in the context of broadband LED light passing through gas, specifically CO2. The Beer-Lambert Law, expressed as I/I0 = exp(kv*l) = exp(sigma*N*l), highlights the wavelength dependence of the absorption coefficient (kv). The challenge lies in integrating the transmission of multiple wavelengths to determine concentration, as each wavelength has a unique extinction coefficient. The solution involves utilizing density and absorption cross-section, which are not wavelength dependent, to extract concentration information.
  • Understanding of Beer-Lambert Law and its mathematical formulation
  • Knowledge of absorption coefficients and extinction coefficients
  • Familiarity with broadband light sources, specifically LEDs
  • Basic principles of spectroscopy and light transmission through gases
  • Research methods for integrating transmission data from broadband light sources
  • Study the calculation of absorption cross-sections for various gases
  • Explore techniques for measuring light intensity before and after passing through a medium
  • Learn about advanced spectroscopic methods for concentration determination
Researchers, chemists, and engineers involved in spectroscopy, gas analysis, and optical measurement techniques will benefit from this discussion.
nordmoon
Let say that you use a LED and direct it through a gas. You measure the 'light' transmitted through the gas and the 'light' entering the gas to obtain the transmission.
Since the Beer–Lambert law is wavelength dependent and the LED is broadband within the region of a for example C02 band, how can you determine the transmission of this wavelength integrated light with the ultimute goal of determine the concentration of the species investigated? Beer–Lambert law states that
I/I0 = exp(kv*l) = exp(sigma*N*l)where kv (absorption coefficient) is wavelength dependent. You have calculated kv per wavelength, but since the light measured is broadband how can you 'simulate' the transmission with known kv? Sigma is the absorption cross section.
I guess the problem is that the light 'contains many wavelength (and not just one)' and that the Beer law is for one wavelength since the absorption coefficient is wavelength dependent. So how can you extract the concentration information in such arrangement? The detector sees a passband of wavelengths and each wavelength has its own extinction coefficient. Thismeans that the detector sees a summation of the effect of each individual wavelength within the passband.
I hope I made any sense.
Hi,
concentration information can be obtained from the density and cross section [of the materials used]..these are not wavelength dependent.
14K
12K
  • · Replies 152 ·
12K
