New Reply
Quick Karnaugh Map Question
Share Thread Thread Tools
Nov8-10, 02:55 PM   #1
Make a circuit to multiply two 2-bit numbers
AB and CD together to produce a 4-bit output.
(a) construct a truth table to represent all states of the inputs and
the corresponding outputs.
(b) make a Karnaugh map for each output bit. Write down the Boolean algebraic expressions that describe the clusters in each map.
(c) design a logic circuit for each output bit to perform the multiplication.
Ok well I am on part b, I have done the truth table already, but I have one problem when making the Karnaugh map, how do I know when to put a 0 or 1 in a place, like if they output is 0000, I guess I put a 0, but if it's something like 0110, do I put a 0 or a 1? I don't understand how I am suppose to know which numbers are high and low, can someone help please? thanks!
For example the truth table here, http://en.wikipedia.org/wiki/Karnaugh_map#Truth_table, how do they know what f(A,B,C,D) is?
Truth table:
A(1) A(0) B(1) B(0) C(3) C(2) C(1) C(0)
0 0 0 0 0 0 0 0
0 0 0 1 0 0 0 0
0 0 1 0 0 0 0 0
0 0 1 1 0 0 0 0
0 1 0 0 0 0 0 0
0 1 0 1 0 0 0 1
0 1 1 0 0 0 1 0
0 1 1 1 0 0 1 1
1 0 0 0 0 0 0 0
1 0 0 1 0 0 1 0
1 0 1 0 0 1 0 0
1 0 1 1 0 1 1 0
1 1 0 0 0 0 0 0
1 1 0 1 0 0 1 1
1 1 1 0 0 1 1 0
1 1 1 1 1 0 0 1
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Nov8-10, 03:53 PM   #2
Mentor
Quote by mmmboh View Post
Truth table:
0 0 0 0 0 0 0 0
0 0 0 1 0 0 0 0
0 0 1 0 0 0 0 0
0 0 1 1 0 0 0 0
0 1 0 0 0 0 0 0
0 1 0 1 0 0 0 1
0 1 1 0 0 0 1 0
0 1 1 1 0 0 1 1
1 0 0 0 0 0 0 0
1 0 0 1 0 0 1 0
1 0 1 0 0 1 0 0
1 0 1 1 0 1 1 0
1 1 0 0 0 0 0 0
1 1 0 1 0 0 1 1
1 1 1 0 0 1 1 0
1 1 1 1 1 0 0 1
You make a K-map for each of the 4 output bits, and use the 4 input bits to label the rows and columns. Then for each entry, you use the output bit value to fill in the square that corresponds to the input code.
Nov8-10, 03:53 PM   #3
Mentor
BTW, one tip for putting tables in your posts is to use the "code" tags. That makes the forum use non-proportional font, so things stay lined up in the columns you typed them in.
New Reply
Tags
binary, karnaugh map, truth table
Thread Tools
Similar Threads for: Quick Karnaugh Map Question
Thread Forum Replies
Karnaugh Maps Calculus & Beyond Learning Materials 54
Why do Karnaugh map work? Electrical Engineering 2
karnaugh map Quantum Physics 1
Karnaugh maps? General Math 1
Karnaugh Map Equation Electrical Engineering 0
