| New Reply |
Mixing household bleach with urine |
Share Thread |
| Dec3-09, 02:35 AM | #35 |
Admin
You need realtively high concentration of chlorine to be able to see its color. If you smell the bleach, there is chlorine in teh air. But as highly reactive it won't last long - it will react with vitrtually everything in the house (say - it slowly decolorizes carpeting, or your favorite coat).
-- ChemBuddy chemical calculators - buffer calculator, stoichiometry calculator www.ph-meter.info - ph meter, ph electrode |
| May18-10, 09:44 PM | #36 |
| May18-10, 09:54 PM | #37 |
especially with large quantities of partially dried animal urine
| Dec1-10, 03:24 PM | #38 |
There's a better way than using clorox to get rid of the urine smell. Clorox also damages carpets irreparably. Household bleach might work if you're ready to evacuate the house for a day or so while the chlorine gas dissipates. Otherwise you can neutralize the smell with an H2O2 peroxide solution bought at the grocery store. You can tell if it's (the peroxide) reacting with the urine if it begins to foam slowly after a minute or so. When you treat a urine-stained carpet with peroxide, it will also make a soft bubbly sound after a minute (hold your ear close). As long as it bubbles you need to keep treating the carpet. Then dry the carpet with a vacuum and towels.
I once 'rescued' a pet infested house by treating all of the floors with 25 gallons of clorox over a period of a week. It was highly unpleasant but the house increased in value by 125% when I was finished. I didn't die either. |
| Dec21-10, 07:51 PM | #39 |
I cannot believe that after reading all of these responses, and maybe I just missed it, but not one person mentioned "Mustard Gas." Mixing Bleach with Ammonia, or Urine (Animal or Human) which contains Ammonia, creates a homemade version of mustard gas. This stuff is not military grade mustard gas, but it is the closest one can come to creating this biological terror gas at home. In fact, mixing bleach with urine, ammonia, vinegar should not be done unless you're MacGuyver or some grunt in the trenches, who just happens to have all the ingredients necessary to make this weapon -and needs to make it! Bottom line.... Don't mess with this stuff!
| Dec22-10, 02:59 AM | #40 |
| Dec22-10, 03:51 AM | #41 |
Admin
I think nobody mentioned that, because it has nothing to do with the mustard gas.
| Dec22-10, 11:24 AM | #42 |
Why not mention it? That is exactly what it is.... Check anywhere on the internet, and you can verify that mixing any of these chemicals will absolutely produce a "homemade" grade of this lethal gas. It's just ironic to me because when I hear "Bleach & Ammonia" I automatically think mustard gas. And I did some checking... Most people I asked, when I mentioned, bleach and ammonia automatically thought mustard gas too. It is just strange to me that on a forum where there are so many people that I would consider intelligent, no one would call it that -or at the very least make mention of its biological uses and clear potential for danger as a gas. And, it's like I said before... I am not saying this combination is military grade, but it is a lesser, but still very toxic, version of what the military produces. Listen friend, this hits me close to home because these components nearly killed me some years back. I still suffer from the affects of the combination of these chemicals. I solemnly believe that promoting the dangers of these chemicals, even if only when mixed when urine is present, will definitely save lives.
| Dec22-10, 12:59 PM | #43 |
Admin
Mixing ammonia and bleach can produce chloramines, not a mustard gas.
| Dec26-10, 08:12 PM | #44 |
I use about 10 percent bleach in water; using it
for the shower since college my problem isn't getting rid of the smell, but how to keep them from coming back????? the ten percent stuff is a lot more safe, i spray it on my hang down curtains -without worrying about color or smell. |
| Dec31-10, 04:10 PM | #45 |
This is officially my favorite forum thread from the entire internet of all times.
| Dec31-10, 04:24 PM | #46 |
| Jan1-11, 11:14 AM | #47 |
Sodium Bicarbonate (Baking Soda) should help.
Just rub the dry powder into the offending areas. |
| Feb7-11, 12:24 AM | #48 |
I have asked about 10 different people the question. I came close on a few people
(VETS) from all the organic chemisty they take, but no one really knew what was really being created in the reaction. One got it right for the Acid Base reaction... if that is still true.. I clean up after my cats in the basement of my house, sort of a small area- as I have on problem cat.. she is now better on Prozac... But I would pour the thick type of bleach on the urine. Then mop up the accident. Sometime the reaction would be so bad, my eyes would start watering, my chest would get tight. I could hardly breath. Then I would stumble out of the area and wonder what the heck is going on? I stopped using such large amounts, but it was so cheap. So, Mustard Gas... that is hard to believe. Thanks so much the answer!! |
| Feb7-11, 12:26 AM | #49 |
Sounds like chlorine gas.
| Feb7-11, 12:54 AM | #50 |
I truly don't understand why people perpetuate the myth that chlorine + ammonia --> mustard. It's simply not true. Besides, if you were exposed to mustard, you'd have the tell-tale blisters to show afterward. Sulfur mustards are prepared by chlorinating thiodiglycol or by reaction of ethylene and sulfur dichloride. If you need further evidence, look at the structure of the reactants and products: Mustards (whether sulfur, nitrogen, or other derivatives) ALL have carbon chains in them. Neither Cl2 nor NH3 have any carbon whatsoever in them. Mustard agents are not things that can be prepared "accidentally" and the precursors involved are regulated under the 1997 Chemical Weapons Convention (although some do appear in household products).
Just because it's not mustard doesn't mean the vapors produced aren't dangerous. Besides being toxic, the chloramines and hydrazine (under the right conditions) produced are carcinogenic. |
| Feb7-11, 12:24 PM | #51 |
I'm thinking that someone somewhere said (posted on the Internet) that you could make your own version of mustard gas (tearing, choking nastiness) by mixing these two together. Then someone else came along that didn't know the chemistry of mustards and just assumed that "what they saw on the Internet" was to be taken literally.
Thanks, Al Gore! Now go screw up something else... |
| New Reply |
Similar discussions for: Mixing household bleach with urine
| Thread | Forum | Replies | ||
| bleach and vinegar | Chemistry | 4 | ||
| REDOX titration of bleach help! | Chemistry | 4 | ||
| Bleach Oxidation Reactions | Biology, Chemistry & Other Homework | 4 | ||
| Health and urine. | Biology | 11 | ||
| Urine | Biology | 5 | ||
