| New Reply |
File that cannot be deleted |
Share Thread | Thread Tools |
| Feb17-11, 04:49 PM | #1 |
Recognitions:
Recently I discovered a file (dated Feb. 13, 2011, time 8:07 P.M. (EST)) that cannot be deleted and does not respond to any commands, such as move, rename, open, etc. I have "unlocker assistant", but it doesn't work here.
The date stamp corresponds to a time when I was surfing Physics Forum and "physics form" is part of the file name. From what I was able to deduce I was in the General Math forum at that time. I believe I was looking at a question where there was a link to another file, which had to opened by "Open Office", so I presume I was looking at the linked file. Since then, that particular question no longer appears in the forum. Any suggestions - I just want to get rid of it. |
| Feb17-11, 08:07 PM | #2 |
Is this in Windows, Linux, or OS X? In general, you may be able to get rid of the file by clearing your cache (and forms, and downloaded files, etc. in whichever browser it is that you use (sorry for the broad stroke, but there's not so much to work with here!) If it persists, you may have to use the CS solution (i.e. reboot the machine, and then try again--sometimes you end up with odd sharing / file locking violations that prevent files from being touched).
| Feb18-11, 03:43 AM | #3 |
If you're on Windows and really desperate to delete it, you could try booting up in Safe Mode. The file is probably being used by something that is always running in the background. Booting in Safe Mode will keep them from starting so that they can't grab and hold the files.
| Feb18-11, 07:19 AM | #4 |
If you are running windows, get a LINUX boot disc, start in LINUX remove the file and then restart in windows.
| Feb18-11, 04:59 PM | #5 |
Recognitions:
My operating system is Windows XP. In general if a file is locked because something is using it, "unlocker assistant" will handle it. In this case, when trying to do anything with the file, the computer acts as if it is not there. For example, "properties" gives me a complete blank, including 0 file length, although windows explorer gives it a length.
| Feb18-11, 06:43 PM | #6 |
| Feb18-11, 06:56 PM | #7 |
Recognitions:
Try logging in as a different user and deleting the file. On my system, I have multiple hard drives, with a second instance of Windows installed on one of of the "other" hard drives. I boot into that for doing backups and if needed restores of the primary OS partitions. The second OS could also be used to delete files that the primary OS won't delete.
| Feb19-11, 12:22 AM | #8 |
I've had this problem before. Windows can't touch it and sometimes throws up errors for it.
The only way to remove it was to boot in Linux. Even a fresh install of Windows couldn't touch it. |
| Feb20-11, 04:44 PM | #9 |
Recognitions:
I tried safe mode and I got the same result (file can't be touched). I have no desire to do anything drastic, so if there is no relatively easy solution, I'll just leave it there.
| Feb20-11, 04:46 PM | #10 |
Burn it to disc and boot from it. You can try out the OS without installing it, run it from the disc. Using this you can see your windows files and delete it. This should take an hour tops and most of that is because of downloading (20 minutes without download time). |
| Feb21-11, 10:38 PM | #11 |
Try system restore. Use a restore point before the problem occured. This is effective against most viruses. I use two disc drives to prevent cross contamination of restore points. A worst case solution is to reformat your hard drive. Again, you need a second hard drive to make it less painful. Copy your non-system files you wish to save to the other drive. i have yet to hear of a bug that can't be killed that way, but, you need a second drive for this fix.
| Feb22-11, 04:56 AM | #12 |
Also, system restore doesn't affect your personal files. So it probably wouldn't touch this folder. |
| Feb22-11, 04:10 PM | #13 |
Recognitions:
File has path C:\Documents and Settings\Herb\Local Settings\Temp\(file name)
I'm Herb |
| Feb22-11, 04:13 PM | #14 |
Again, I recommend you try the Linux boot disc method. |
| Feb22-11, 06:20 PM | #15 |
| Feb22-11, 07:04 PM | #16 |
Recognitions:
| Feb22-11, 07:34 PM | #17 |
Have you tried using disk clean up? It should have an option to clean the Temp folder. If it doesn't need it in there, it will delete it. Is there any particular reason you need to delete it?
It may be the internet cache for that user, you could clear the cache in the browser and that may delete all the content of the file/folder. |
| New Reply |
| Thread Tools | |
Similar Threads for: File that cannot be deleted
| Thread | Forum | Replies | ||
| using a batch file to create NAMELIST input file for FORTRAN | Programming & Comp Sci | 0 | ||
| how can Capture Text form image file and save it as txt file or word file | Computers | 2 | ||
| Make a Pdf file into an ordinary web file (html file)? | Computing & Technology | 3 | ||
| My network directory file synch batch file thing :) | Computing & Technology | 2 | ||
| Checking In Songs - Can You Save Onto Hard Drive If Original Song File Deleted? | Computing & Technology | 1 | ||
