Row reducing the matrix of a linear operator
The discussion revolves around understanding the row reduction of a matrix representing a linear operator from R5 to R4, specifically focusing on finding a basis for the image and kernel of the operator. Participants explore the implications of reduced row echelon form and the properties of linear independence.
  • Homework-related
  • One participant expresses confusion about how to determine linear independence from the reduced row echelon form, specifically regarding the significance of having a single 1 entry in certain columns.
  • Another participant explains that linear independence can be inferred from the structure of the vectors formed by the columns with leading 1s, demonstrating that a linear combination leading to zero implies all coefficients must be zero.
  • There is a discussion about why the corresponding columns of the original matrix form a basis for the image of the linear operator, with references to the preservation of independence through row reduction.
  • Participants inquire about the process of finding a basis for the kernel from the row-reduced form, discussing the relationship between the kernel and the solutions to the equation Av = 0.
  • One participant provides a detailed explanation of how to express vectors in the kernel as linear combinations of specific vectors derived from the row-reduced form.
  • Another participant asks about the purpose and implications of row reducing a matrix, seeking clarity on the information gained from the reduced form.
  • A response clarifies that row operations correspond to multiplying by invertible matrices, preserving properties of the original matrix.
Participants generally agree on the process of row reduction and its implications for linear independence and the structure of the image and kernel. However, there remains some uncertainty regarding the conceptual understanding of these properties, as evidenced by the questions raised.
Some participants express limitations in their understanding of the concepts involved, particularly regarding the implications of row reduction and the definitions of linear independence and basis. There are unresolved aspects related to the interpretation of the results from row reduction.
*FaerieLight*
I'm having difficulty understanding the concepts presented in the following question.
I'm given a matrix,
[2,4,1,2,6; 1,2,1,0,1; ,-1,-2,-2,3,6; 1,2,-1,5,12], which is the matrix representation of a linear operator from R5 to R4.
The question asks me to find a basis of the image and the kernel of the map.
Row-reducing the matrix gives
[1,2,0,0,-1; 0,0,1,0,2; 0,0,0,1,3; 0,0,0,0,0,] as the reduced row echelon form. I'm told that the columns 1, 3 and 4 are linearly independent, and hence the corresponding columns of the original matrix form a basis of the image of A. This is what I don't understand. How do I know that these columns are linearly independent? I suppose it has something to do with the fact that these columns are the only ones with a single 1 entry, while all the rest of the entries are 0, above and below. But why should this feature necessarily mean that the columns are linearly independent?
After determining the linearly independent columns, why should the corresponding columns of the original matrix correspond to a basis of the image of A?
Also, how would I find a basis for the kernel from the row-reduced echelon form?
Thanks very much.
I'm given a matrix,
Because that means your vectors are of the form
[tex]v_1= \begin{bmatrix}1 \\ a_1 \\ a_2 \\ ...\end{bmatrix}[/tex]
[tex]v_2= \begin{bmatrix}0 \\ 1 \\ b2 \\ ...\end{bmatrix}[/tex]
[tex]v_3= \begin{bmatrix}0 \\ 0 \\ 1 \\ ...\end{bmatrix}[/tex]
etc.
Now, suppose we have some linear combination [itex]\alpha_1v_1+ \alpha_2v_2+ \alpha_3v3+ ...= 0[/itex]
That gives
[tex]\begin{bmatrix}\alpha_1 \\ \alpha_1a_1+ \alpha_2 \\ \alpha_1a_2+ \alpha_2b_2+ \alpha_3\\ ...\end{bmatrix}= \begin{bmatrix} 0 \\ 0 \\ 0 \\ ...\end{bmatrix}[/tex]
The first component gives [itex]\alpha_1= 0[/itex]. The second component gives [itex]\alpha_1a_+ \alpha_2= 0[/itex] and since [itex]\alpha_1= 0[/itex], [itex]\alpha_2= 0[/itex]. The third component gives [itex]\alpha_1a_2+ \alpha_2b_2+ \alpha_3= 0[/itex]. Since [itex]\alpha_1= 0[/itex] and [itex]\alpha_2= 0[/itex], [itex]\alpha_3= 0[/itex], etc. That is, all scalars in the linear combination are 0 which means the vectors are independent.
Imagine taking A times each of the vectors <1, 0, 0, 0, 0>, <0, 1, 0, 0, 0>, <0, 0, 1, 0, 0>, <0, 0, 0, 1, 0>, and <0, 0, 0, 0, 1>, the "standard basis" for R5 in turn. You would get, of course, just the 5 columns of the matrix. Since "row reduction" does not change "independence", you know that the first, third, and fourth rows of the row-reduced form are independent, so are the first, third, and fourth rows of the original matrix and we know they are in the kernel. The other two, the second and fifth columns, are not independent so they map <0, 1, 0, 0, 0> and <0, 0, 0, 0, 1> into combinations of the other three columns- that is those three columns span the image as well as being independent and so are a basis for the image.
Thanks very much.
A vector, v, is in the kernel of A if and only if Av= 0. Imagine solving the equation by row reducing the augmented matrix. The added column is all 0s so no matter what the row operations are, the last column will remain all 0s. That is, row reducing the augmented matrix for your example will give
[tex]\left[\begin{array}{ccccc}1 & 2 & 0 & 0 & -1 \\ 0 & 0 & 1 & 0 & 2\\0 & 0 & 0 & 1 & 3\\0 & 0 & 0 & 0 & 0 \end{array}\right|\left|\begin{array}{c}0 \\ 0 \\ 0 \\ 0\end{array}\right][/tex]
If call a vector in the domain <u, v, x, y, z> those say that we must have u+ 2v- z= 0, x+ 2z= 0, and y+ 3z= 0. From the second and third equations, x= -2z and y= -3z. From the first equation, z= u+ 2v so that x= -2(u+ 2v)= -2u- 4v and y= -3(u+ 2v)= -3u- 6v. That is, we can write any vector in the kernel as <u, v, x, y, z>= <u, v, -2u-4v, -3u- 6v, u+ 2v>= <u, 0, -2u, -3u>+ <0, v, 4v, -6v, 2v>= <1, 0, -2, -3>u+ <0, 1, 4, -6, -2>v which tells us that any vector in the kernel can be written as a linear combination of <1, 0, -2, -3> and <0, 1, 4, -6, -2>. And those are clearly independent because of the "<1, 0" and "<0, 1" first two terms.
Thanks for that! It was a very helpful explanation.
I have another question. What exactly does row reducing a matrix do to it? Why is it that we can gain so much information about the matrix and the linear operator it represents from the row reduced form?
Thanks
Every row operation is the same as multiplying by an "elementary matrix"- the matrix you get by applying that row operation to the identity matrix. So if A can be row reduced to B then there exist a series P1, P2, P3, ..., Pn so that Pn...P3P2P1A= PA= B. Since every row reduction is invertible, their product, P, is also invertible. It follows then that if A is invertible, so is B, etc. For example, if B is the identity matrix, Pn...P3P2P1A= I then Pn...P3P2P1 is the inverse matrix to A. Since Pn...P3P2P1= Pn...P3P2P1I, applying the same row operations, that reduce A to the identity matrix, to the identity matrix gives [itex]A^{-1}[/itex].
