| New Reply |
Physics lab normal force please help!!!!! |
Share Thread | Thread Tools |
| Mar9-12, 10:02 AM | #1 |
A 1000-kg car moves at a maximum speed so that it does not skid off the 50-m radius level track. If the coefficient of static friction between the road and wheels is 0.80. What is the maximum speed? Assume that the gravitational constant is 10.0 N/kg =10.0 m/s. Use the simulations in 4.5 Car Circles a Track to check your answers.
Write an equation for the vertical y-component form of Newton's second law. Determine the magnitude of the normal force. Then use a force law equation to determine the magnitude of the static friction force. Write an equation for the radial component form of Newton's second law. Use this to determine the maximum speed that the car can travel so that it does not skid (so that friction can provide the needed force to keep the car moving in a circle). Once you have calculated the maximum speed adjust the speed slider in the 4th simulation to this speed and see if the car stays on the track. |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Mar9-12, 10:16 AM | #2 |
hi albarnett17! welcome to pf!
![]() with these questions, do everything in the order the question tells you to start with … … what do you get? |
| Mar9-12, 10:52 AM | #3 |
Idk any equations or where to put what in the equations i have no idea how to do this.
| Mar9-12, 10:57 AM | #4 |
Physics lab normal force please help!!!!!draw a free body diagramwhat do you get?
| Mar9-12, 11:08 AM | #5 |
Ok i did i have a diagram but i still dont get sorry but i really do not kno like almost anything in physics
| Mar9-12, 12:08 PM | #6 |
ok, now we have to do F = ma vertically (in the y direction), from your diagram
a (acceleration) vertically is obvously zero, and your only vertical forces are the normal force N, and the weight (which you're calling V, but we usually call it W) … ok so what is the equation (with the numbers in)? |
| Mar10-12, 04:26 PM | #7 |
F=10000*0
f=0 |
| Mar10-12, 05:15 PM | #8 |
what's F?
| Mar11-12, 11:01 AM | #9 |
f= 0
| Mar11-12, 11:09 AM | #10 |
yes, but what is F made of?
| Mar11-12, 12:00 PM | #11 |
Force idk m*g
| Mar11-12, 12:05 PM | #12 |
| Mar11-12, 12:11 PM | #13 |
im so confused man heres what i got for
question 1.F(n) = mg F(n) =(1000)(9.81) F(n) =9810 N SF=UF SF=(0.80)(9810) Sf=7848 |
| Mar11-12, 02:21 PM | #14 |
hi albarnett17!
![]() ![]() (except thequestion says g=10 N/kg, so the friction force is 8000 N) now use that in F = ma for the x direction |
| New Reply |
| Thread Tools | |
Similar Threads for: Physics lab normal force please help!!!!!
| Thread | Forum | Replies | ||
| normal force mastering physics | Introductory Physics Homework | 1 | ||
| Physics HW help!? Normal Force between two objects? | Introductory Physics Homework | 3 | ||
| Solving for the normal force (Physics assignment) | Introductory Physics Homework | 11 | ||
| physics problem: normal force | Introductory Physics Homework | 3 | ||
