| New Reply |
Short circuits and sources. |
Share Thread | Thread Tools |
| May5-12, 09:30 AM | #1 |
Hello Everybody,
My question is: Why when a resistor is in parallel with a "short circuit" the voltage across the resistor is zero, & so will the current passing through it? But when instead of a resistor we have a voltage source, this is not the case? "I was informed that the voltage source generates current even though it is in parallel with a short circuit.. I dont get it? :/ Another thing, if we have a curent source in parallel with a short circuit.. what will happen exactly? Will the voltage across the current source be zero(like in resistor's case) or not(like in voltage source's case)? Thanks in advance. Please elaborate :D |
| May5-12, 10:04 AM | #2 |
so, shorting=connecting 0Ω so obviously all current goes through the short leaving nothing to resistor if you do , i guess current will flow if shorting wire is of bit high resistance if not the wire might burn because the resistance connecting two terminals is zero, maximum current will flow which might over heat the wire |
| May5-12, 10:05 AM | #3 |
It is convenient in exercises to use ideal values in order to concentrate on the principle being studied without having to worry about the details. However with your question, you are using ideal components in ways that do not result in realistic answers.
If you put a voltage source across a short circuit, the current produced will be E/0. The answer to your first question is, a voltage source is very different than a resistor. The answer to your second question is yes it will be zero (E = I * R: R =0), however you cannot say that the voltage is not zero when putting a voltage source across a short circuit - that voltage is undefined. |
| May5-12, 10:06 AM | #4 |
Mentor
To answer your second question regarding the current source: an ideal current source is something that outputs a steady current no matter what, and ideal wire is a perfect conductor that has zero residence. So if you connected these together, you would get a current flowing from the source through the wire with no voltage drop.
However the ideal current source and ideal wire are sort on par with the massless rope and the frictionless plane. They are not realistic by any means. They exist for pedagogical purposes to remove unnecessary complications when learning the fundamentals of circuit theory. Let's say you implemented a reasonably constant current source in real life (something that would require electronics to actively control and monitor its output). Any real wire that you connected across it would have some non-zero resistance R. If the source outputs a current I, then the voltage across the wire (and hence across the source) would be IR in accordance with Ohm's law. This voltage would be very small due to the small resistance. Similarly, if you shorted the terminals of a voltage source of voltage V with a wire having a resitance R, then there would be a current of V/R across the source. Since the resistance of a wire is so small, a tremendous amount of current will flow. This is true unless if V is also very very small, which is not usually the case. This could very well be enough current to melt the wire, or, in the case of a battery, to overheat the battery, risking fire and explosion. DO NOT ever short the terminals of a battery! |
| May5-12, 10:11 AM | #5 |
Recognitions:
These are both extreme examples of following a theoretical definition to its limits.
A voltage generator will deliver any current necessary to maintain a voltage output. A current generator will generate any voltage necessary to keep its current flowing at the correct value. They are handy concepts when applied sensibly, but putting a voltage generator across a short circuit is getting ridiculous. It is a bit like an unmovable object meeting an unstoppable force. Don't take it seriously. Putting a short circuit across a current generator is not so bad. It will just generate the right current and there will be no voltage across the short circuit. |
| May5-12, 10:20 AM | #6 |
Thank you all, but I kind of realised that you are talking about real-life cases. I am just talking about circuits in books, and only in books.
Just a quick conclusion: Voltage source parallel with short circuit is undefined and NOT zero. Current source will keep on producing current no matter what. Voltage of resistor in parallel with short circuit .. is zero. Correct me if am wrong. |
| May5-12, 10:22 AM | #7 |
| May5-12, 10:35 AM | #8 |
So?
Thanks skeptic2, but what now? Please summarize an answer to my question. |
| May5-12, 10:35 AM | #9 |
Recognitions:
Unfortunately or otherwise, this is a practical Forum and we have to point out that sometimes the proposed circuit is not possible and may even be contradictory. An impossible situation is still impossible even if the book says it is OK. |
| May5-12, 10:47 AM | #10 |
Thanks my friend :)
And concerning the voltage across the IDEAL current source (if it was connected in parallel with short circuit? ) |
| May5-12, 10:52 AM | #11 |
Mentor
| May5-12, 10:58 AM | #12 |
Cepheid thanks.
It is just the whole concept that irritated me. |
| May5-12, 12:05 PM | #13 |
Why not assign a value of 0.01Ω to the short, 0.1Ω for the internal resistance of your voltage source and a voltage of 10V to your voltage source. Then your current will be 10/(0.11) or 91 A. This means you'll have a voltage of (9.1 * 0.01) or 0.91 volts across the short. If you have a current source of 100A, then you will have 100A * 0.01Ω or 1V across the short. |
| May5-12, 12:08 PM | #14 |
Thanks dear, thanks for bearing with me :D
Thank you all. |
| New Reply |
| Thread Tools | |
Similar Threads for: Short circuits and sources.
| Thread | Forum | Replies | ||
| Current Sources in Parallel when Simplifying Circuits | Electrical Engineering | 11 | ||
| short circuits | Electrical Engineering | 9 | ||
| Thevenin Equivalent for circuits with dependent sources | Engineering, Comp Sci, & Technology Homework | 2 | ||
| Circuit breakers and short circuits | Introductory Physics Homework | 1 | ||
| What are the main sources of gamma ray bursts both short and long duration | Advanced Physics Homework | 1 | ||
