New Reply
The meaning of abstraction and implementation in computer science
Share Thread Thread Tools
Jul16-12, 11:08 AM   #1
Hello, I was wondering if someone could give me a "for dummies" definition of abstraction and implementation in computer science? The online definitions are very technical and I can't quite wrap my mind around them.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
Jul16-12, 08:26 PM   #2
Mentor
How about you provide us with the definitions you've found, and then we can do our best to translate them into more basic terms.
Jul22-12, 12:31 AM   #3
The question is ill-defined so my answer will be very generic.
In its simplest form abstraction is encapsulating the parts of a system into separate little black boxes. This allows people to use them without requiring knowledge of how they work, or their internals, and prevents one part of the program from adversely affecting another.
This is done in a number of ways.
Say you want to write a program that reads in data from a file, and applies a function to said data, then prints it.
You do could do it like this (code is Python unless otherwise specified):
Code:
if = open ("data.txt", "r")  # open input file
of = open ("data2.txt", "w") # open output file
for line in f.readlines():   # for each line ...
    line.strip ()            # stupid trailing LF
    line.reverse ()          # reverse it
    of.write (line + "\n")   # save it in output
But that would suck. To use abstraction.
Code:
data = read_in (filename)
data = process (data)
write_out (filename, data)
Much easier with magic black boxes!
How are they defined? Probably like this:
Code:
def read_in (filename):
    f = open (filename, "r")
    return f.readlines ()
def process (d):
    for i in d:
        i.reverse ()
    return i
def write_out (filename, d):
    f = open (filename, "w")
    for i in d:
        f.write (d + "\n")
So long as the API (interface) between the functions is defined, each developer can work away in private on his/her function without stepping on the others' toes (if nothing goes wrong). The developer of process () doesn't need to know or care how the data is read in. All he needs to know is that he receives a list of data in a particular format, he performs the business logic on it, then he returns the modified version in a particular format. If something changes like the method of reading the data, it's similarly easy to redo becuase of the separation of functions.
When you include a module e.g.
Code:
import math
You are again using abstraction.
Abstraction is also used to represent data.
Code:
# not code, had to use code tags for formatting!
car
- engine
  - size, horsepower
- controls
  - steer, start, stop etc
- payload
  - number of passengers, max weight possible
We can rapidly swap engines from another car, etc
Code:
# "copy" engine and all its contained properties (size, HP, status etc)
red_car.engine = blue_car.engine
I put "copy" in quotes because Python doesn't always copy here, but the result will be the same data in both car engines.
We can also use the concept of inheritance to derive a more specalised car from the base car
convertible_car
- derived from car
- exactly the same but adds new features: roof up, roof down, get roof state
Then you no longer need separate code to process each car
Code:
for this_car in list_of_cars:
    this_car.start_up () # we start ANY car like this
    try:
        this_car.roof_up ()
    except:
        print ("This car can't do that")
So you don't need to write separate code for each type of car.
Jul22-12, 12:39 AM   #4
I'd like to get into design patterns (usin abstraction for program structure) but that's kind of long. In any case the first example (text processor) is a very crude exmaple of this.
New Reply
Thread Tools
Similar Threads for: The meaning of abstraction and implementation in computer science
Thread Forum Replies
Similarities / Differences between Computer Science and Computational Science Academic Guidance 2
Computer Engineering vs Computer Science ?? Academic Guidance 4
Computer science or computer science with mathematics? Career Guidance 4
Computer Science VS Computer Engineering (Academic Research....? Similar?) Academic Guidance 3
No computer science at the computer science forum! Forum Feedback & Announcements 8
