New Reply
What, physically, are the Miller planes of a crystal?
Share Thread
Apr9-12, 08:06 AM   #1
I'm trying to learn crystallography and I've had trouble with this concept since the very beginning of the course. It's been so long since it's been introduced that I'd be embarrassed to ask the prof. Right now, I seem to understand the principles of diffraction based on the Miller model; that is, based on the phase changes of radiation scattered from Miller planes at non-n*λ spacings. However, I don't understand what these planes actually are in real life. For a diffraction grating, I can physically see the ridges on the grating, which "validates" the model for me. However, for something as complicated and non-plane-like as a protein, I completely fail to see where the planes originate.
Could someone please give me some help?
PhysOrg.com physics news on PhysOrg.com
>> Surprising turns in magnetic thin films could lead to better data storage
>> Novel synthesis technique for high efficiency conversion of source gas to diamond
>> Scientists capture crystallization of materials in nanoseconds
Apr9-12, 08:40 AM   #2
Well, I always remember that the Miller indices indicate the vector that is perpendicular to the miller plane. The vector is defined in terms of lattice vectors. So in the simplest case, a lattice is 3 orthogonal vectors of the same length. For any arbitrary miller indices, you now have a vector you can draw in 3D. Now using your vector math, you can define the plane that is perpendicular to that vector. The atoms that lie in that plane are the diffraction grating.
Apr10-12, 03:04 PM   #3
They are like real space crystallographic planes but in reciprocal space
Apr14-12, 04:48 PM   #4
But aren't the crystalographic planes arbitrarily defined? How can mathematical constructs produce physical effects?
Apr15-12, 04:11 AM   #5
Imagine the argument made by Miller applied not to the planes, but simply to two point particles (proteins in your case). If the phase change is zero, the reflected waves add constructively. However, since this is just for two particles, it might not amount to much. Now consider that the incoming and reflected waves define an imaginary plane running through the particles. If this plane is one of the Miller planes, then it "hits" every particle in the lattice. Which means the argument can be repeated for every particle, and ALL the reflected waves add constructively. An effect THAT large, you WILL see.
Jul5-12, 02:16 PM   #6
An easy way that I found to remember / find which Miller Indices belong to which plane, is to to count how many atoms laterally, and how many atoms vertically make up the plane. That is, [1 3] would be a plane that, if you start at *any* given atom in a crystal, the plane will be defined by drawing a line from that point, to the atom that is 1 row up, and 3 atoms backwards. That is. this plane would be defined by the outermost points (X) of:
X X X X
. X X X X
Jul5-12, 02:38 PM   #7
Mentor
Quote by Roo2 View Post
Have you ever held a 3-D ball-and-rod model of a simple crystal (say a cubic one like NaCl) in your hands and looked at it while rotating it? You can see the planes vividly at certain orientations.
For a two-dimensional version, draw a rectangular array of dots on a sheet of paper, and then look at it at a grazing angle from different directions.
Jul6-12, 12:36 PM   #8
The planes are not associated with one protein molecule but with the lattice made from many protein molecules. I suppose you are talking about a crystallized protein.
Jul23-12, 02:00 AM   #9
it's just convention. don't be bother too much.
New Reply
Similar discussions for: What, physically, are the Miller planes of a crystal?
Thread Forum Replies
miller index planes and directions relationship Biology, Chemistry & Other Homework 4
Miller Indexing crystal structures General Physics 0
Miller Indices Crystallographic Planes Question Materials & Chemical Engineering 1
Crystal Planes, Miller Indices: Cubic Lattice Atomic, Solid State, Comp. Physics 14
Distance b/w two miller planes Atomic, Solid State, Comp. Physics 1
