How do I calculate the mass density, given the mass?
  • Context: Undergrad
  • Thread starter Thread starter silmaril89
    Density Mass
The discussion revolves around calculating mass density and probability density given a mass function and a probability function, respectively. Participants explore the implications of defining mass and probability as functions of position, particularly in non-uniform distributions and constrained geometries like a ring.
  • One participant asks how to find mass density as a function of position given a mass function M(x,y) = (4/π)xy, specifically for a ring of radius 1.
  • Another participant questions the validity of defining mass as a function of position, suggesting that mass density should be defined instead.
  • A participant clarifies that their inquiry is related to probability density, seeking to understand how to derive total probability from a given probability function P(x,y) = (4/π)xy.
  • Concerns are raised about the interpretation of P(x,y) as a probability, noting that it could yield nonsensical results if treated as a finite probability at specific points.
  • Participants discuss the need to express probability density in terms of an infinitesimal volume or area element to maintain dimensional consistency.
  • One participant suggests rewriting the probability density function (PDF) as a function of a single variable, θ, and notes that the original function cannot be a valid PDF due to negative values.
  • Another participant proposes a modified PDF, P(θ) = (4/π)|sin(θ)cos(θ)|, which is non-negative and integrates to 1 over the specified range.
  • Normalization of the PDF is discussed, with one participant expressing uncertainty about their approach to achieving it.
Participants express differing views on the validity of defining mass and probability as functions of position. There is no consensus on the best approach to derive mass density or probability density, and multiple competing interpretations are present throughout the discussion.
Participants highlight limitations in the definitions and assumptions regarding mass and probability functions, particularly concerning their behavior in continuous distributions and the implications of dimensional analysis.
silmaril89
Let's say you have the mass of an object as a function of position, how would I go about finding the mass density as a function of position? I want a general answer, one that doesn't assume the mass has uniform density (that would be trivial).
As an example, can you solve this?
Say you have a ring of radius 1 with its center at the origin of a cartesian coordinate system. You are given that the mass [itex]M(x,y) = \frac{4}{\pi} x y[/itex]. Find the mass density of the ring.
The reason I want to do this, is to find the total mass of some object given the mass as a function of position, but in order to do the necessary integral it seems I need the mass density.
Any help would be greatly appreciated
Mass as a function of position doesn't make much sense. (At least not for a continuous distribution.) Given the mass density as a function of position, you can integrate to find the total mass. Are you sure that's not what you are thinking of?
I'm sure. I understand how it doesn't make much sense to think of mass as a function of position. I have another question that led me to this one. The real question is about probability density. I have that the probability of some thing occurring to be [itex]P(x,y) = \frac{4}{\pi} x y[/itex], but I want the total probability of this thing occurring if I don't know x or y. I figured I need the probability density, how would I get this?
Your analogy is correct- it would only make sense if P is the probability density. In the same way that a point can't have a (finite) mass, one single event out of an infinite number of possibilities cannot have a (finite) probability. You can, however, specify the amount of mass in an infinitesimal volume, dm = density*dV, and you can specify the probability of an event occurring in the infinitesimal range of a continuous space of possible outcomes.
eg. if P is the actual probability then the outcome (1,1) has a probability of 4/pi of happening, which is greater than 1 and completely nonsensical.
Yes, but the specification is that P(x,y) is only valid on a ring of radius 1 (i.e. (1,1) is not a valid point).
Basically, I have the probability of an event occurring being equal to [itex]P(x,y) = \frac{4}{\pi} x y[/itex], but the issue is that I don't know what the probability for the event to occur if the position (x,y) is random and only on a ring of radius 1. What can I do?
That's a fair point, but here's another reason P cannot be a probability- consider two arbitrarily close points in this space- (x,y) and (x+dx, dy). The probabilities of each of these two events occurring are P(x,y) and P(x+dx,dy), and so the probability of either occurring is P(x,y) + P(x+dx,y). Now let's add a third probability- P(x+2*dx, dy). The probability of any of these three occurring is the sum of each of the probabilities.
This becomes problematic very quickly because we are adding together finite (nonzero) quantities, but we haven't specified how small dx is- it can be so arbitrarily small that this sum contains infinitely many nonzero terms - leading to an infinite probability - within a finite space, or region of possible outcomes. To deal with this you need to multiply P by the area element dxdy to keep the probability within an infinitely small possibility space infinitely small.
One more reason might help explain this- the units don't make sense. If x spans some range of possibilities, then it could have a dimension, but the probability must be dimensionless. For example, if x and y are lengths, say, distance from the bullseye of an archery board, then P has units of m^2. But expressing a probability in units of area doesn't make sense.
The easiest thing to do will be to re-write the PDF as a function of one variable, e.g. P(θ). Btw, your function cannot be a valid PDF over the whole unit circle because it has negative values.
[tex]P(\theta) = \frac{4}{\pi} \mid \sin \theta \cos \theta \mid[/tex]
In this case the probability that the event will occur in the range (θ1,θ2) is
∫P(θ)dθ from θ1 to θ2
P(θ) is the PDF, not the probability.
There is one more issue, P(θ) is not normalised.
Normalization is tough, but I just divided by ([itex]\theta_2 - \theta_1[/itex]), but something tells me that isn't right.
Wolfram alpha is a great tool for this stuff
http://www3.wolframalpha.com/Calculate/MSP/MSP10821a2c28b265g1d9a800005305h834i2614295?MSPStoreType=image/gif&s=26&w=167&h=35
P(θ) = (1/2)*|sin(θ)cos(θ)| should be correct
Yes, that is non-negative everywhere and integrates to 1 over -π < θ < π.
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 16 ·
