New Reply
Does the Earth carry a charge?
Share Thread
Jul31-12, 01:56 AM   #18
Quote by zonde View Post
You have piece of one metal and piece of different metal. You connect them and for some small time electricity flows between them until charge builds up and stops the current.
If you just put two metals next to each other you won't get current. In order for you to get current you have to connect them with some sort of substance that allows ions to move in the other direction. This only works because the substance that moves charge through the fluid does so through bound electrons that move a lot less slowly then free electrons.
Jul31-12, 11:46 PM   #19
Recognitions:
Gold Membership Gold Member
Quote by twofish-quant View Post
Let's compare two cases:
1) two different disconnected metals in electrolyte
2) two different connected metals in electrolyte
Ions in electrolyte move lot less slowly then electrons in metal. So that means that electron distribution in metals is stable compared to slowly moving ions (two dynamical processes are decoupled). As we observe that these two cases are different (stable) electron distribution should be different in two cases.
Aug15-12, 04:42 PM   #20
Recognitions:
Is Earth charged? Maybe, but what is the Earth? Does the Earth stop at the surface? We know from previous posts that the Earth's surface is negatively charged. Does the Earth include the troposphere, the ionosphere, the Van Allen belts, the magnetosphere? Is it smarter to think of the Earth as part of a dynamic system involving the sun and the interplanetary medium?
The following post will help us to think about these questions.
The lightning we are all familiar with is generated in clouds by charge separation and electric fields. http://www.sciencedaily.com/releases...0601140934.htm
Electrons are accelerated from Earth into the Van Allen belts:
When particularly intense lightning discharges in thunderstorms coincide with high-energy particles coming in from space (cosmic rays), nature provides the right conditions to form a giant particle accelerator above the thunderclouds.
The cosmic rays strip off electrons from air molecules and these electrons are accelerated upwards by the electric field of the lightning discharge. The free electrons and the lightning electric field then make up a natural particle accelerator.
The accelerated electrons then develop into a narrow particle beam which can propagate from the lowest level of the atmosphere (the troposphere), through the middle atmosphere and into near-Earth space, where the energetic electrons are trapped in the Earth's radiation belt and can eventually cause problems for orbiting satellites. These are energetic events and for the blink of an eye, the power of the electron beam can be as large as the power of a small nuclear power plant.
http://www.sciencedaily.com/releases...0413202850.htm
Highly energetic electrons in the outer Van Allen belt are lost into the interplanetary medium during solar storms:
During powerful solar events such as coronal mass ejections, parts of the magnetized outer layers of sun's atmosphere crash onto Earth's magnetic field, triggering geomagnetic storms capable of damaging the electronics of orbiting spacecraft. These cosmic squalls have a peculiar effect on Earth's outer radiation belt, a doughnut-shaped region of space filled with electrons so energetic that they move at nearly the speed of light.
"During the onset of a geomagnetic storm, nearly all the electrons trapped within the radiation belt vanish, only to come back with a vengeance a few hours later," said Vassilis Angelopoulos, a UCLA professor of Earth and space sciences and IGPP researcher.
The missing electrons surprised scientists when the trend was first measured in the 1960s by instruments onboard the earliest spacecraft sent into orbit, said study co-author Yuri Shprits, a research geophysicist with the IGPP and the departments of Earth and space sciences, and atmospheric and oceanic sciences.
"It's a puzzling effect," he said. "Oceans on Earth do not suddenly lose most of their water, yet radiation belts filled with electrons can be rapidly depopulated."
Even stranger, the electrons go missing during the peak of a geomagnetic storm, a time when one might expect the radiation belt to be filled with energetic particles because of the extreme bombardment by the solar wind.
Where do the electrons go? This question has remained unresolved since the early 1960s. Some believed the electrons were lost to Earth's atmosphere, while others hypothesized that the electrons were not permanently lost at all but merely temporarily drained of energy so that they appeared absent.
"Our study in 2006 suggested that electrons may be, in fact, lost to the interplanetary medium and decelerated by moving outwards," Shprits said. "However, until recently, there was no definitive proof for this theory."
To resolve the mystery, Turner and his team used data from three networks of orbiting spacecraft positioned at different distances from Earth to catch the escaping electrons in the act. The data show that while a small amount of the missing energetic electrons did fall into the atmosphere, the vast majority were pushed away from the planet, stripped away from the radiation belt by the onslaught of solar wind particles during the heightened solar activity that generated the magnetic storm itself.
http://www.sciencedaily.com/releases...0129150958.htm
The outer Van Allen belt swells and shrinks by a factor of 100 according to the way it fits into the larger system of its interaction with the solar wind and CMEs, and with Earth http://www.sciencedaily.com/releases...0131143745.htm
In reality, where do the extra energy and particles come from? Where do they disappear to, and what sends them on their way? How do these changes affect the rest of Earth's magnetic environment, the magnetosphere? We will find out with the RBSP mission. http://www.sciencedaily.com/releases...0717183418.htm
Respectfully submitted,
Steve
New Reply
Similar discussions for: Does the Earth carry a charge?
Thread Forum Replies
What charge must a spherical raindrop of diameter 1.0 mm carry if it remains suspend Introductory Physics Homework 10
How to distinguish the charge carry by different object after rub by something?? Introductory Physics Homework 1
Why do capacitors 'in series' each carry the same charge? Introductory Physics Homework 6
How much work must be done to carry a +2.3 X 10^-3 C charge from 65 cm to 15 cm? Introductory Physics Homework 12
Earth's charge Introductory Physics Homework 1
