| New Reply |
Latent Heat (enthalpy) of Fusion changes with Pressure? |
Share Thread | Thread Tools |
| Mar8-12, 09:59 AM | #1 |
If the melting point depends on the pressure, does the latent heat of fusion also depend on the pressure? The equation relating the entropy of fusion to the enthalpy of fusion is given by:
[tex]\Delta H=T\Delta S[/tex] where T is, apparently, the temperature of melting. So, if the melting point increases with pressure, then as isentropic melting occurs the latent heat (enthalpy) of fusion decreases linearly? |
| Mar9-12, 04:05 AM | #2 |
Recognitions:
Generally [itex] dH=C_p dT +(V-T \frac{\partial V}{\partial T}|_p}dp [/itex] with the last term in the brackets defines the isobaric thermal expansion coefficient. Just integrate along the phase boundary [itex]T_\mathrm{melt}(p)[/itex] for the two phases in equilibrium. |
| Aug1-12, 08:27 PM | #3 |
Hello Sir,
Latent heat of anything can simply be calculated by taking the difference between enthalpy after and before. I dont' remember but the dependence of the enthalpy before and after will tell you if it will change the latent heat. |
| New Reply |
| Thread Tools | |
Similar Threads for: Latent Heat (enthalpy) of Fusion changes with Pressure?
| Thread | Forum | Replies | ||
| Specific Heat of Nickel / Latent Heat of Fusion | Introductory Physics Homework | 9 | ||
| Speed of Bullet with specific latent heat of fusion and heat capacity [HELP ME PLEASE | Advanced Physics Homework | 1 | ||
| Latent Heat of Fusion of Ice | General Physics | 1 | ||
| latent heat of fusion/latent heat of vaporization | Introductory Physics Homework | 2 | ||
| specific heat capacity and latent heat of fusion | Introductory Physics Homework | 4 | ||
